iPi Automation Add-on
Revision as of 09:32, 4 December 2015 by Vmaslov (Talk | contribs)
Using iPi Integration Add-on
Communication Library
    • x86 32-bit version
    • x64 64-bit version
This library provides a general way of communication with supported applications. A client program establishes a connection to an application. Then, using this connection, it sends commands to the application. After executing a command, the application synchronously sends a response to that command back to a client program. Also, through the same connection, an application asynchronously notifies a client program about occurring events, such as the end of a long-running operation.
Error codes
/tr>
ConstantDescription
IPI_OKOperation succeeded.
Connecting and disconnecting
Sending commands
Consuming events
    "arguments":
        <arguments_list_json_string>
    "success": true
    "success": true,
    "result":
      <result_json_string>
// Response in case of error
    "success": false,
// Event without arguments
// Event including arguments
    "arguments":
iPi Recorder Commands
Parameter NameTypeMandatory /
Optional
Allowed ValuesDescription
Arguments
No arguments
Result
// Request
    "command": "get-app-info"
// Response
    "success":true,
    "result":
        "appName": "iPi Recorder 3",
Optional
Arguments
Result
Empty result
// Request
    "command": "open-studio",
    "arguments":
        "filePath": "D:\iPiMocap\test_record.iPiVideo"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "exit"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "open-home-screen"
// Response
    "success": true
Optional
Arguments
No arguments
Result
kindstringmandatorycamera
depth-sensor
microfon
Device type.
selectedbooleanmandatorytrue
false
Device selected status.
failedbooleanmandatorytrue
false
Device filed status.
// Request
// Response
    "success":true,
    "result":
            "kind": "camera",
            "model": "PlayStation Eye",
            "selected": false,
            "failed": false
            "kind": "depth-sensor",
            "id": "Default Kinect 2",
            "selected": true,
            "failed": true,
            "error": "Is not available"
            "kind": "microphone",
            "selected": false,
            "failed": false
Optional
Arguments
Result
Empty result
// Request
    "command": "open-recorder"
    "arguments":
        "selectedDevices":
// Response
    "success":true
Optional
Arguments
Result
Empty result
Events
successbooleanmandatorytrue
false
cancelledbooleanmandatorytrue
false
// Request
    "arguments":
        "duration": 3,
        "startDelay": 1
// Response
    "success": true
// Event
    "arguments":
        "success": true,
        "cancelled": false
Optional
Arguments
Result
Empty result
Events
false
false
hh:mm:ss.sssssss
Duration of the recording.
// Request
    "command": "start-recording",
    "arguments":
        "filePath": "D:\iPiMocap\test_record.iPiVideo",
        "startDelay": 1
// Response
    "success": true
// Event
    "event": "recording-stopped",
    "arguments":
        "success": true,
        "cancelled": false,
        "fileSize": 39975560,
        "frameCount": 197
stop-recorder command stops recording.
Optional
Arguments
No arguments
Result
Empty result
Events
false
false
hh:mm:ss.sssssss
// Request
    "command": "stop-recording"
// Response
    "success": true
// Event
    "arguments":
        "success": true,
        "cancelled": false,
        "frameCount": 197
Optional
Arguments
No arguments
Result
depth-sensor
microfon
Device type.
false
false
Device failed status.
statisticsJSON object
optional
Camera statistics.
// Request
// Response
    "success":true,
    "result":
            "kind": "camera",
            "selected": false,
            "failed": false,
            "statistics":
                "frameRate":50.0,
                "frameDropsPerSecond":0.0,
                "badFramesPerSecond":0.0,
                "totalFrameDrops":0,
                "totalBadFrames":0
            "selected": false,
            "failed": false,
            "statistics":
                "frameRate":50.0,
                "totalBadFrames":0
Optional
Arguments
No arguments
Result
Properties for SETUP Stage:
videoModestringmandatory
Selected RGB video mode.
Possible videoMode values.
audioModestringoptional
Selected audio mode. This field is included into the response, if microphone selected.
globalDevicePropsJSON object
optional
"Darkening"
"Extra Darkening"
screenLayoutstringmandatory
For RGB cameras:
"Color"
For depth sensors:
"Depth"
"Picture in picture"
"Side by side"
Selected screen layout.
false
Properties for RECORD Stage:
false
Valid file path
"None"
"Background subtraction"
"JPEG"
Result
Empty result
// Request
// Response
    "success": true,
    "result":
        "videoModeList":
            "640x480 color @ 60Hz",
            "640x480 color @ 40Hz",
            "640x480 color @ 30Hz",
            "640x480 color @ 25Hz",
            "320x240 color @ 60Hz",
            "320x240 color @ 50Hz",
            "320x240 color @ 37Hz",
            "320x240 color @ 30Hz"
        "screensInRow": 1,
        "screenLayout": "Color",
        "screenLayoutList":
            "Color"
        "globalDeviceProps":
                "None",
                "Darkening",
                "Extra Darkening"
        "recordingStartDelay": 1,
        "destinationFilePath": "D:\iPiMocap\<time stamp>.iPiVideo",
        "colorCompression":"Jpeg",
        "jpegQuality":100,
        "depthCompression":"BackgroundSubtraction"
Optional
Arguments
videoModestringoptional
optional
"Darkening"
"Extra Darkening"
screenLayoutstringoptional
For RGB cameras:
"Color"
For depth sensors:
"Depth"
"Side by side"
Setting screen layout.
false
false
Valid file path
"None"
"JPEG"
Result
Empty result
// Request
    "arguments":
        "colorCompression": "jpeg",
    "recordingStartDelay": 0,
// Response
    "success": true
Optional
Arguments
false
Result
Empty result
// Request
    "arguments":
        "screensInRow": 2,
	"hideBackground": true
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "command": "open-player",
    "arguments":
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
No event arguments
// Request
    "command": "play-forward"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
playing-stopped event is generated when playing is competed (reached the first frame) or stopped by user
No event arguments
// Request
    "command": "play-backward"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "frame-forward"
// Response
    "success": true,
    "error": "Last frame reached"
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "frame-backward"
// Response
    "success": true,
go-to-frame command select current frame. If case of invalid frame index error message returned.
Optional
Arguments
Frame index. The first frame index is 0, the last frame index is <total number of frames> - 1.
Result
Empty result
// Request
    "command": "go-to-frame",
    "arguments":
        "frameIndex": 27
// Response
    "success": true
