iPi Automation Add-on
Using iPi Integration Add-on
Communication Library
- x86 32-bit version
- x64 64-bit version
This library provides a general way of communication with supported applications. A client program establishes a connection to an application. Then, using this connection, it sends commands to the application. After executing a command, the application synchronously sends a response to that command back to a client program. Also, through the same connection, an application asynchronously notifies a client program about occurring events, such as the end of a long-running operation.
Error codes
| Constant | Description |
Connecting and disconnecting
Sending commands
Consuming events
iPi Recorder Commands
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Device type. |
Device selected status. |
Device failed status. |
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
Duration of the recording. |
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Device type. |
| statistics | JSON object |
Camera statistics. | ||
// Request { "command": "refresh-device-list" } // Response { "success":true, "result": [ { "kind": "camera", "model": "PlayStation Eye", "id": "\\\\?\\usb#vid_1415&pid_2000&mi_00#7&2ed872d7&0&0000#{4cff9941-d72f-4951-9291-03d8fc97fe30}", "selected": true, "failed": false, "statistics": { "frameRate": 50.0, "frameDropsPerSecond": 0.0, "badFramesPerSecond": 0.0, "totalFrameDrops": 0, "totalBadFrames": 0 } }, { "kind": "microphone", "model": "USB Camera-B4.04.27.1", "id": "\\\\?\\usb#vid_1415&pid_2000&mi_00#7&1c1ec232&0&0000#{4cff9941-d72f-4951-9291-03d8fc97fe30}", "selected": true, "failed": false, "statistics": { "frameRate": 50.0, "frameDropsPerSecond": 0.0, "badFramesPerSecond": 0.0, "totalFrameDrops": 0, "totalBadFrames": 0 } } ] }
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Selected RGB video mode. |
Possible videoMode values. |
For RGB cameras: |
Selected screen layout. |
Valid file path |
"None" |
| Result | ||||
| Empty result | ||||
| Arguments | ||||
For RGB cameras: |
Setting screen layout. |
Valid file path |
"None" |
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| No event arguments | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| playing-stopped event is generated when playing is competed (reached the first frame) or stopped by user | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
