iPi Recorder Installation
Revision as of 12:37, 29 January 2016 by Andrew (Talk | contribs)
  1. Select needed components
Important!
Components
  • iPi Recorder 3.x.x.x. This is required component and cannot be unchecked.
    iPi Recorder itself.
