iPi Automation Add-on
- 1 Overview
- 2 License and Trial
- 3.1 Communication Library
- 3.2 Command Syntax
- 3.3 iPi Recorder Commands
- x86 32-bit version
- x64 64-bit version
iPiExec Console Application
Using iPiExec
Usage: iPiExec recorder | studio recorder - connecting to iPi Recorder. studio - connecting to iPi Mocap Studio.
SAMPLE
| Parameter | Description |
| jsonEvent | Event string. |
| Constant | Description |
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Device type. |
Device selected status. |
Device failed status. |
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
Duration of the recording. |
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Device type. |
| statistics | JSON object |
Camera statistics. | ||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Selected RGB video mode. |
Possible videoMode values. |
For RGB cameras: |
Selected screen layout. |
Valid file path |
"None" |
| Result | ||||
| Empty result | ||||
| Arguments | ||||
For RGB cameras: |
Setting screen layout. |
Valid file path |
"None" |
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| No event arguments | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
Type of the project. |
Gender of actor. |
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Type of the cameras. |
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
Show skin flag value. |
Show bones flag value. |
Show cameras flag value. |
Show background flag value. |
Show video flag value. |
Show depth flag value. |
Hide background flag value. |
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
Gender of actor. |
| lowerLength | number | optional | Double | Length of lower leg between knee and ankle joints in meters. |
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
// Request { "command": "refit-pose" } // Response { "success": true } // Event { "event": "refit-pose-finished", "arguments": { "mismatch": -0.0346799499867484, "translation": { "x": 0.20735317468643188, "y": 0.93647444248199463, "z": 0.1268109530210495 }, "joints": [ { "name": "Hip", "rotation": { "w": 0.99089264869689941, "x": -0.024765072390437126, "y": -0.13141168653964996, "z": -0.015792140737175941 } }, { "name": "LowerSpine", "rotation": { "w": 0.9960486888885498, "x": 0.028381859883666039, "y": -0.083706416189670563, "z": -0.008648967370390892 } }, { "name": "MiddleSpine", "rotation": { "w": 0.9960486888885498, "x": 0.028381859883666039, "y": -0.083706416189670563, "z": -0.008648967370390892 } }, { "name": "Chest", "rotation": { "w": 0.9960486888885498, "x": 0.028381859883666039, "y": -0.083706416189670563, "z": -0.008648967370390892 } }, { "name": "Neck", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } }, { "name": "Head", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } }, { "name": "EffectorHead", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } }, { "name": "LClavicle", "rotation": { "w": 0.99793654680252075, "x": 0.0059945755638182163, "y": 0.046108484268188477, "z": 0.044281467795372009 } }, { "name": "LShoulder", "rotation": { "w": 0.9549943208694458, "x": -0.034553475677967072, "y": 0.29447850584983826, "z": 0.0086394213140010834 } }, { "name": "LForearm", "rotation": { "w": 0.91743868589401245, "x": -0.036340668797492981, "y": -0.39591813087463379, "z": 0.015319216065108776 } }, { "name": "LHand", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } }, { "name": "RClavicle", "rotation": { "w": 0.995156466960907, "x": -0.040068801492452621, "y": -0.048379208892583847, "z": 0.075615249574184418 } }, { "name": "RShoulder", "rotation": { "w": 0.965262770652771, "x": -0.0052053602412343025, "y": 0.26098120212554932, "z": -0.011395715177059174 } }, { "name": "RForearm", "rotation": { "w": 0.99951714277267456, "x": -0.020441532135009766, "y": -0.0027645230293273926, "z": -0.023236606270074844 } }, { "name": "RHand", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } }, { "name": "RThigh", "rotation": { "w": 0.79308795928955078, "x": 0.068257540464401245, "y": 0.60094189643859863, "z": 0.072259068489074707 } }, { "name": "RShin", "rotation": { "w": 0.79541802406311035, "x": 0.053630385547876358, "y": 0.60230922698974609, "z": -0.040715586394071579 } }, { "name": "RFoot", "rotation": { "w": 0.99298214912414551, "x": -0.11810562759637833, "y": -0.00553984334692359, "z": -0.0026492751203477383 } }, { "name": "RToe", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } }, { "name": "EffectorRToe", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } }, { "name": "LThigh", "rotation": { "w": 0.99825394153594971, "x": -0.0010303414892405272, "y": 0.021972890943288803, "z": 0.054818056523799896 } }, { "name": "LShin", "rotation": { "w": 0.99794912338256836, "x": 0.059693548828363419, "y": 0.023080151528120041, "z": -0.0013148610014468431 } }, { "name": "LFoot", "rotation": { "w": 0.98020839691162109, "x": -0.18852591514587402, "y": -0.054500121623277664, "z": -0.026062563061714172 } }, { "name": "LToe", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } }, { "name": "EffectorLToe", "rotation": { "w": 1.0, "x": 0.0, "y": 0.0, "z": 0.0 } } ] } }
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
Export format. |
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
Export format. |
| Result | ||||
| Empty result | ||||
| Events | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Events | ||||
Camera calibration quality. |
// Request { "command": "run-calibration", "arguments": { "markerSpotSize": "large", "calibrationMode": "fast" } } // Response { "success": true } // Event { "event": "calibration-finished", "arguments": { "elapsedTime": 49.0548727, "canceled": false, "rgbCalibrationStat": [ { "quality": "perfect", "reprojectionError": 0.8999624, "misdetects": 0.36743924 }, { "quality": "perfect", "reprojectionError": 0.5540145, "misdetects": 0.328137815 }, { "quality": "perfect", "reprojectionError": 0.8146306, "misdetects": 0.5209761 }, { "quality": "perfect", "reprojectionError": 0.567752242, "misdetects": 1.13636363 } ] } } // Event { "event": "progress-updated", "arguments": { "elapsedTime": 5.3501876, "remainingTime": 0.80599999999999994, "progress":0.86486486486486491, "fps":6.169 } }
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
Name of predefined rig. |
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
| No arguments | ||||
| Result | ||||
| Arguments | ||||
| Result | ||||
| Empty result | ||||
| Arguments | ||||
Fbx version for FBX format. |
| Result | ||||
| Empty result | ||||
// Request { "command": "export-animation", "arguments": { "profilePath": "D:\\iPiMocap\\test.bvh" } } // Response { "success": true }
