iPi Recorder Release Notes
ver. 3.2.3.45
N E W F E A T U R E S:
ver. 3.1.4.43
U N D E R T H E H O O D:
ver. 3.1.3.38
- Memory usage optimizations.
ver. 3.1.2.36
B U G F I X E S:
ver. 3.1.1.34
B U G F I X E S:
ver. 3.1.0.33
B U G F I X E S:
ver. 3.0.1.32
B U G F I X E S:
ver. 3.0.0.31
- Audio and video export.
