Video Recording
Revision as of 12:44, 19 January 2017 by Vmaslov (Talk | contribs)
Please run iPi Recorder and follow recording workflow as described in user's guide for the program.
Framerate
4 cameras at 320 by 240 resolution
4 cameras at 640 by 480 resolution at 60 frames per second
6 cameras at 640 by 480 resolution at 60 frames per second
USB controllers
Performance Tips
Recording with multiple cameras is a very resource consuming operation. If the system does not provide sufficient resources, you may experience different problems like frame drops, unstable frame rate, premature ending of recording. All these end up in poor quality records that cannot be successfully processed in iPi Mocap Studio. Below are some recommendations which help you to avoid problems with hardware performance during recording.
  • Use dedicated physical drive (HDD or SSD, or even RAM drive when having enough memory) for recording onto it. When recording onto OS drive, performance may suffer badly from other working processes reading and writing to that drive in parallel.
  • Ensure PC is not set to any kind of power saving mode like **Power Saver** plan or **Battery Saver** mode in Windows 10.
  • Connect laptop to a power line if possible. If not, charge battery to full before going on to recording.
  • Stop programs which perform many computations or disk operations. Examples of such programs are torrent clients and anti-virus software.
  • Unplug unnecessary high-bandwidth USB devices like external drives, Wi-Fi adapters (if not needed for distributed recording).
