iPi Recorder Release Notes
Revision as of 11:35, 25 January 2017 by Vmaslov (Talk | contribs)
ver. 3.2.6.48
Version 3.2.6.48
Jan 25, 2017
Download-24.png  Download
 N E W    F E A T U R E S:
  • Warning about possible performance issues on **RECORD** tab.
 B U G    F I X E S:
  • Results of some checks on recording start were ignored. For instance, recording started after user answered **No** when presented a warning about low FPS.
ver. 3.2.5.47
Version 3.2.5.47
Nov 10, 2016
 B U G    F I X E S:
ver. 3.2.3.45
Version 3.2.3.45
Jul 14, 2016
ver. 3.1.4.43
Version 3.1.4.43
Apr 25, 2016
ver. 3.1.3.38
Version 3.1.3.38
Nov 19, 2015
  • Memory usage optimizations.
ver. 3.1.2.36
Version 3.1.2.36
Jun 18, 2015
 B U G    F I X E S:
ver. 3.1.1.34
Version 3.1.1.34
Mar 06, 2015
 B U G    F I X E S:
ver. 3.1.0.33
Version 3.1.0.33
Dec 29, 2014
 B U G    F I X E S:
ver. 3.0.1.32
Version 3.0.1.32
Nov 13, 2014
 B U G    F I X E S:
ver. 3.0.0.31
Version 3.0.0.31
Nov 03, 2014
