Depth Sensors Comparison
Depth Sensors Support
- Modern depth sensors:
- MS Kinect 2 (XBOX One Kinect sensor plus Kinect Adapter for Windows)
- Orbbec Astra (PRO)
- Intel RealSense D435 and D415
- ASUS Xtion 2
- First generation depth sensors:
- MS Kinect v1 (Kinect for Windows sensor or [1] sensor plus adapter)
- ASUS Xtion and ASUS Xtion Live devices (and also PRO modifications for developers)
- PrimeSense Carmine 1.08
As to modern depth sensors, MS Kinect 2 (Kinect for XBOX One) sensor remains the best choice for full body motion capture. The quality and accuracy of depth map from MS Kinect 2 are the best on the market.
Brief Comparison of Depth Sensors
| Device | Pros | Cons |
| Kinect 2 for Windows / Kinect for Xbox One |
| First-generation Depth Sensors |
Technologies
Drivers
To use the sensors, you may need to download and install device drivers and software libraries for ASUS Xtion / ASUS Xtion Live / PrimeSense Carmine.
