Depth Sensors Comparison
Revision as of 09:34, 20 July 2018 by Andrew (Talk | contribs)
Depth Sensors Support
Kinect 2 (Kinect for XBOX One)
Orbbec Astra (PRO)
Intel RealSense D415 and D435
ASUS Xtion 2
Microsoft Kinect for Windows
ASUS Xtion Live
ASUS Xtion
PrimeSense Carmine 1.08
As to modern depth sensors, MS Kinect 2 (Kinect for XBOX One) sensor remains the best choice for full body motion capture. The quality and accuracy of depth map from MS Kinect 2 are the best on the market.
Important! But only single MS Kinect 2 (Kinect for XBOX One) sensor can be connected to one PC due to limitation in Microsoft Kinect SDK 2. Each MS Kinect 2 (Kinect for XBOX One) sensor can be connected to a separate computer, Distributed Recording feature must be used.
Brief Comparison of Depth Sensors
Sensor Pros Cons
  • Higher resolution of depth and RGB video
  • Lower noise, better quality of point cloud
  • Higher overall tracking quality can be expected
  • Much better feet tracking
  • Low mutual sensors interference
  • More tolerant to lighting conditions
  • Has mount for tripod
  • Doesn't like shinning fabric
  • Requires USB 3.0 controller and external power supply
  • Only single sensor on one PC is supported by Microsoft Kinect SDK 2
  • Does not work on Windows 7 (requires Windows 8 and higher)
First-generation Depth Sensors
  • Ensures tracking quality comparable with Kinect 2, but hardware requirements are not so strong
  • Requires USB 2.0 controller
  • Multiple sensors can be plugged to single computer
  • Works on Windows 7 and higher
  • Lower resolution
  • Lower accuracy
  • Less tolerant to lighting conditions
  • Higher mutual interference of sensors leads to more noise in case of using several sensors
  • No mount for tripod
Orbbec Astra (PRO)
See above (as first-generation depth sensors)
Plus:
  • Higher price than price of first-gen sensors
  • Astra has mount for tripod but M6 instead of 1/4″
Technologies
Drivers
To use the sensors, you may need to download and install device drivers and software libraries for ASUS Xtion / ASUS Xtion Live / PrimeSense Carmine.
