Depth Sensors Comparison
Revision as of 12:34, 20 July 2018 by Andrew (Talk | contribs)
Depth Sensors Support
Kinect 2 (Kinect for XBOX One)
Orbbec Astra (PRO)
Intel RealSense D415 and D435
ASUS Xtion 2
Microsoft Kinect for Windows
ASUS Xtion Live
ASUS Xtion
PrimeSense Carmine 1.08
As to modern depth sensors, MS Kinect 2 (Kinect for XBOX One) sensor remains the best choice for full body motion capture. The quality and accuracy of depth map from MS Kinect 2 are the best on the market.
Important! But only single MS Kinect 2 (Kinect for XBOX One) sensor can be connected to one PC due to limitation in Microsoft Kinect SDK 2. Each MS Kinect 2 (Kinect for XBOX One) sensor can be connected to a separate computer, Distributed Recording feature must be used.
Comparison
Main features of depth sensors:
Place Sensor Price (approx) Technology Depth FOV (vertical) Depth Resolution Depth FPS Interface Multiple Sensors on One PC External Power Supply Tripod Mount
1 Kinect 2 (Kinect for XBOX One) $160 Time-of-Flight 60° 512x424 (very good quality!) 30 USB 3.0 no required has (1/4″)
2 First-gen depth sensors from $30 Infrared Coded Structured Light 45° 640x480 (interpolated, actual: 320x240 or even less) 30 USB 2.0 yes not required (except Kinect v1) no
2 Orbbec Astra (PRO) $160 Infrared Coded Structured Light 45° 640x480 (interpolated, actual: 320x240 or even less) 30 USB 2.0 yes not required has but M6 (not 1/4″)
3 Intel RealSense D435 $180 Infrared Coded Structured Light combined with stereo RGB matching 65.5° (but only 42° for RGB) up to 1280x720 (but very noisy, inaccurate and with a lot of artifacts like waves and blur!) up to 90 USB 3.0 yes not required has (1/4″)
4 ASUS Xtion 2 $270 Time-of-Flight 52° (but can be mounted in vertical position, then - 74°) 640x480 (interpolated: actual is less than 320x240) 30 USB 3.0 no not required has on bottom and right sides (1/4″)
Major Pros and Cons of depth sensors:
Place Sensor Pros Cons
  • Higher FOV
  • Higher resolution of depth and RGB video
  • Lower noise, better quality and accuracy of point cloud
  • Higher overall tracking quality can be expected
  • Much better feet tracking
  • Low mutual sensors interference
  • More tolerant to lighting conditions
  • Has mount for tripod
  • Doesn't like shinning fabric
  • Requires USB 3.0 controller and external power supply
  • Only single sensor on one PC is supported by Microsoft Kinect SDK 2
  • Does not work on Windows 7 (requires Windows 8 and higher)
2 First-generation Depth Sensors
  • Ensures tracking quality comparable with Kinect 2, but hardware requirements are not so strong
  • Requires USB 2.0 controller
  • Multiple sensors can be plugged to single computer
  • Works on Windows 7 and higher
  • Lower FOV
  • Lower resolution
  • Lower accuracy
  • Less tolerant to lighting conditions
  • Higher mutual interference of sensors leads to more noise in case of using several sensors
  • No mount for tripod
See above (as first-generation depth sensors)
Plus:
  • On sale
Plus:
  • Higher price than price of first-gen sensors
  • Astra has mount for tripod but M6 instead of 1/4″
  • Up to 90 FPS
  • High resolution of depth map
  • Good field-of-view (FOV)
  • Very compact
  • Great tech support, fast fixes, frequent updates
  • Very low quality of depth map (high noise, many artifacts)
  • Multiple sensor configuration is not practical with this sensors because of accuracy and quality of depth map (cannot be calibrated)
  • RGB camera has significantly lower FOV
4 ASUS Xtion 2
  • Time-of-Flight like Kinect 2
  • Can be fixed in vertical position
  • Very compact
  • Extremely low effective resolution of depth map (too low amount of 3D dots)
  • No mapping between RGB and depth
  • High price
The winner is Kinect 2 (Kinect for XBOX One).
First-generation depth sensors and Orbbec Astra (PRO) share the second place.
Drivers
To use the sensors, you may need to download and install device drivers and software libraries for ASUS Xtion / ASUS Xtion Live / PrimeSense Carmine.
