Sample Videos and Projects (four GoPro)
Revision as of 01:33, 4 August 2018 by Andrew (Talk | contribs)
  • cam1 and cam2 — GoPro HERO4 Silver
  • cam3 and cam4 — GoPro HERO4 Session
GoPro-HERO4.jpg GoPro-HERO4.jpg   GoPro-HERO4-Session.jpg    GoPro-HERO4-Session.jpg
The following settings were used for recording:
  • Resolution: 720p (1280x720)
  • FOV: Wide
  • FPS: 60
Tip: Short description of overall process of recording and processing can be found in Quick Start Guide for Multiple Action Cameras Configuration.
Camera Optics Calibration Video
Camera Calibration Video (.MP4) Camera Parameters (.iPiCam) Recommended Frames for Calibration Recommended Scale for Undistorting
cam1 ↓ cam1-720p-wide.MP4 (13 MByte) ↓ cam1-720p-wide.iPiCam (407 Byte) 50, 880, 1360, 1780, 2110 0.80
cam2 ↓ cam2-720p-wide.MP4 (11 MByte) ↓ cam2-720p-wide.iPiCam (410 Byte) 1, 380, 840, 1220, 2016 0.80
cam3 ↓ cam3-720p-wide.MP4 (41 MByte) ↓ cam3-720p-wide.iPiCam (412 Byte) 1, 340, 1260, 2420, 2910, 3680, 4490, 5120 0.80
cam4 ↓ cam4-720p-wide.MP4 (32 MByte) ↓ cam4-720p-wide.iPiCam (409 Byte) 1, 410, 1100, 1950, 2660, 3320, 3510, 4130 0.80
How to use:
  • Download and install iPi Recorder.
  • Download .MP4 video files from the above table.
  • Run iPi Recorder, click Calibrate Camera Optics in toolbar.
  • For each camera (.MP4 video file):
    • Switch to CALIBRATION tab.
    • Click Open Video button in toolbar, choose appropriate video file.
    • Select a few frames for calibration using timeline and Toggle Current Frame button. You can use recommended frames from the above table or choose frames you like.
    • Click Run Calibration button.
    • Now you see results of calibration. You can adjust scale.
    • Save results to .iPiCam file.
Scene Calibration Sequence
While camera optics calibration is used to determine intrinsic parameters of each camera and can be done once, scene calibration is a process of computing accurate mutual camera positions and orientations in space and should be done for each new cameras setup/configuration. To do it small glowing object called marker is used.
Camera Video with Marker (.MP4) Recommended Sync Frame
cam1 ↓ calib-cam1.mp4 (5 MByte) 685
cam2 ↓ calib-cam2.mp4 (14 MByte) 3743
cam3 ↓ calib-cam3.mp4 (25 MByte) 2514
cam4 ↓ calib-cam4.mp4 (30 MByte) 1739
How to build synchronized multi-camera video:
  • Run iPi Recorder, click Build Combined Video in toolbar.
  • For each video (i.e. camera) in order from cam1 to cam4 do the following steps:
    • Click Add Video in toolbar, choose appropriate video file.
    • Click on PROPERTIES button in the top area of image from camera.
    • Click Load button in section camera parameters in the left panel, choose appropriate .iPiCam file from the previous section (for example, cam3-720p-wide.iPiCam for calib-cam3.mp4 video).
    • Click Edit button in section sync frame in the left panel, choose the first frame where marker becomes visible (see Recommended Sync Frame column), click Set to Current Frame button in toolbar, switch back to BUILD tab.
  • Now video is combined and synchronized but we have to evaluate background (clear scene without marker and moving objects):
    • Choose region on timeline where marker is not visible (for example: from 95 to 665 frames).
    • Click Evaluate Background button in toolbar.
  • You're ready to save result to .iPiVideo file:
    • Choose region to be saved: you can save the whole video or only part where marker is visible (for example: from 690 to 6960 frames).
    • Click Save Combined Video button in toolbar.
four-gopro-calibration.iPiVideo
525 MByte
four-gopro-calibration.iPiCalib
280 KByte
How to use these files:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select four-gopro-calibration.iPiCalib file downloaded on the previous step.
    • select four-gopro-calibration.iPiVideo file downloaded before;
    • switch to Calibration tab and push Calibrate button;
      • the height of first camera over ground plane is about 1.12 m
Action Sequence
As soon as scene parameters found (that is, scene calibration performed) you can record and process video with motions (action video).
cam1 ↓ action-cam1.mp4 (9 MByte) 3940
cam2 ↓ action-cam2.mp4 (40 MByte) 3534
cam3 ↓ action-cam3.mp4 (25 MByte) 3573
cam4 ↓ action-cam4.mp4 (20 MByte) 3570
    • Click Load button in section camera parameters in the left panel, choose appropriate .iPiCam file from the previous section (for example, cam3-720p-wide.iPiCam for action-cam3.mp4 video).
    • Click Edit button in section sync frame in the left panel, choose frame where illumination from camera flash is visible (see Recommended Sync Frame column), click Set to Current Frame button in toolbar, switch back to BUILD tab.
    • Choose region on timeline where scene is almost clear (for example: from 3681 to 3733 frames).
    • Choose region to be saved: you can save the whole video or only part with required motions (for example: from 75 to 3435 frames).
four-gopro-action.iPiVideo
680 MByte
four-gopro-action.iPiMotion
3 MByte
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select four-gopro-action.iPiMotion file downloaded on the previous step.
    • select four-gopro-action.iPiVideo file downloaded before;
    • choose Action project type;
    • choose the following file as scene parameters: four-gopro-calibration.iPiCalib (see previous section)
      • Gender = Male
      • Height = 1.76 m
      • Clothing model = T-Shirt over Long-sleeve Shirt
    • then you can process the video:
      • adjust light position and parameters (It is very important for good tracking quality!)
      • go to the frame with T-pose
      • manually align model with image in each camera
      • adjust actor appearance (manually and/or automatically)
      • run tracking by clicking Track Forward button
      • manually fix tracking errors if any
      • apply Refine Forward/Backward and Jitter Remover to improve animation
Exported Animation
  • Default iPi Rig
FileExtensionBVH.png ↓ BVH Animation ↓
FileExtensionFBX.png ↓ FBX ↓
FileExtensionDAE.png ↓ COLLADA ↓
FileExtensionSMD.png ↓ Valve Source Engine SMD ↓
FileExtensionDMX.png ↓ Valve Source Engine DMX ↓
  • Motion Builder
  • 3ds Max Biped
  • Source Film Maker and Valve Source Engine
FileExtensionSMD.png ↓ Droid Character in SMD Format ↓
FileExtensionDMX.png ↓ Spy Character in DMX Format ↓
