How to Build Synced Multi-Camera Video
Revision as of 14:21, 15 August 2018 by Vmaslov (Talk | contribs)
Preparations
There are two hints here:
  2. To distinguish files from different cameras it is convenient to create a sub-folder for each camera. And name of such sub-folder should contain label/nickname of corresponding camera.
YYYY-MM-DD-session-name
   cam1
   cam2
   cam3
   cam4
Alternatively you can rename video files right after copying (or even during copying) to local disk while you still remember which camera has produced those files. Such approach is used in the following sample: Sample Videos and Projects (four GoPro).
Overall Procedure
  • Run iPi Recorder and click Build Combined Video button in the toolbar at the home screen.
  • For each camera:
    • add video from this camera by clicking Add Video button in the toolbar — see mark (1) on screenshot below
    • choose this camera by clicking on the image from this camera — (2)
    • click button Edit in sync frame section of the left panel (3) and choose a frame with synchronization event — (5)
  • Now videos from all cameras are added and required parameters (camera parameters and synchronization frames) are defined for them.
  • Evaluate background:
    • using markers (6) and (7) select an interval on the timeline where there is no actor and moving objects (the length of this interval should be about a couple of seconds)
    • alternatively, to set an interval on the timeline you can use controls in section INTERVAL of the toolbar — (8)
    • click Evaluate Background button in the toolbar to evaluate background for all cameras simultaneously from the selected interval on the timeline — (9)
    • alternatively:
      • you can evaluate background for each camera separately using button Edit... in section background in the left panel (3) — (A)
      • for details see below
    • using markers (6) and (7) on the timeline or controls (8) in the toolbar, select an interval you want to save to a resulting video
      • for a calibration video it could be an interval where the glowing marker is visible
      • for an action video it could be an interval with needed action sequence or movement
      • or you can save the whole video if you're not sure which exact interval will be used for processing in iPi Mocap Studio
    • click Save Combined Video button in the toolbar and choose destination file name — (C)
      • but in most cases the default value (70%) works very well providing a good balance between image quality and size of the resulting video
  • Finally you can open the resulting .iPiVideo file in iPi Mocap Studio and process it.
Important Aspects
Cameras and Their Parameters
  1. It is strictly mandatory to add cameras in one and the same order for scene calibration and action videos. In other case results of scene calibration will not match action video(s). By the way, you can use drag-and-drop to reorder cameras in the builder.
  2. Don't forget to apply camera parameters by loading them from appropriate .iPiCam file. Remember that this .iPiCam file must be for this specific camera and for exactly the same resolution and view/FOV settings (FPS may differ). The thing is that camera optics parameters significantly vary from item to item (even when all items are of the same make and model) and depends on resolution and view/FOV settings.
  3. You can adjust the scale of undistort filter right in Combined Video Builder:
Be aware that the same scale value must be used for scene calibration and action videos (per camera, of course). For this reason use this feature with a great care.
Synchronization
To build combined video source videos from separate cameras must be synchronized. Current version of Combined Video Builder supports only manual synchronization based on some short/sharp visual event visible in all cameras simultaneously. Frame where such event takes place is called as sync frame. That is, you have to set sync frame for each source video:
We recommend to use the following visual events for synchronization:
  • the moment when you turn on/off flash light (or Sony Move)
  • manual firing of external on-camera flash
For details see How to Record Video with Action Cameras#Synchronization Event.
Example of synchronization using external on-camera flash in manual mode:
Prev. frame
(before sync)
Sync frameNext frame
(after sync)
(In the 3rd camera flash is not directly visible, but you can see illumination produced by this flash.)
How to set synchronization frame:
  • Select required camera and click Edit... button in sync frame section of left panel — see mark (1) on screenshot below.
  • Additional tab SYNC FRAME opens with single video in it.
  • Using timeline (2) choose frame with synchronization event.
    • it is convenient to use buttons Previous Frame and Next Frame to position precisely on required frame — see marks (3) and (4) on screenshot below
  • After that click Set to Current Frame button in toolbar — (5).
  • Now switch back to BUILD tab by clicking on it — (6).
  • Also, you can adjust synchronization frame right in builder using buttons (7) and (8).
  • Alternatively, you can set synchronization frame to current frame visible in BUILDER using button Current Frame — (9).
Background
And the last but not the list thing in the way to combined video is background evaluation. Background is an image of clear scene without actors and moving objects:
There are three ways to evaluate background:
  1. Simultaneously for all cameras
    • this method is the easiest and described above in section #Overall Procedure
    • but it requires that clear scene is simultaneously visible in all cameras which can be problematic to achieve in real life conditions
  2. For each camera (source video) separately
    • select required camera and click Edit... button in background section of left panel — see mark (1) on screenshot below
    • additional tab BACKGROUND opens with single video in it
    • using triangles (2) on timeline or controls (3) in toolbar, select interval on timeline where there is no actor and moving objects (the length of this interval should be about a couple of seconds)
    • after that click Evaluate Background button in toolbar — (4)
    • optionally you can save result (evaluated background) to file on disk to use later with different videos (see below) — (5)
    • now switch back to BUILD tab by clicking on it — (6)
  3. Or you can evaluate background based on other video, save it to file and then just load it when you need background for appropriate camera.
In any case it is worth to check background quality after evaluation using Hide Background button in toolbar of Combined Video Builder:
(In this particular case background subtraction is not ideal but good enough for motion capture needs.)
Sample
You can use the following sample videos to train in this subject without need to record your own videos: Sample Videos and Projects (four GoPro).
