Motion Controllers
- Wrist rotations can be tracked only with motion controllers due to low resolution of video.
- Though head can be tracked with camera, using a motion controller for that purpose greatly reduces the processing time and may provide better accuracy.
Equipment
- PlayStation Move
- Wii Remote with MotionPlus
Prefer Class 1 adapters as they have extended range of operation (up to 100m).
iPi Recorder does not limit the number of connected motion controllers. However, the hardware does. Most Bluetooth adapters can handle up to 4 PS Move controllers (sometimes more). iPi Software supports up to 3 controllers for each actor. Thus, additional Bluetooth adapter(s) would be required. Unfortunately, standard Windows Bluetooth drivers do not support multiple adapters. We used to recommend Motion in Joy drivers that allowed support for multiple adapters, but these drivers are now out of support and thus not available anymore. However, if you use Distributed Recording, you can use multiple adapters (one adapter per computer).
For PS Move, an USB to mini-USB cable is also required to charge your motion controller and for pairing (see next section).
Unfortunately, the latest makes of PS Move do not have a magnetometer. So when buying PS Moves, try to get ones branded for PlayStation 3 console, maybe used. Some earlier PS Moves branded for PlayStation 4 may also have a magnetometer, because we started to see no magnetic data only in the end of 2016. But we do not have 100% evidence of this.
Recording
To get your motion controller in the list of devices, it must be connected to a PC via Bluetooth. But before it can connect to your Bluetooth adapter, the controller must be paired with it. For that, press the Add Controller button in the toolbar, select device type you have, and then follow the instructions specific for this device.
| Buttons | Color |
| Select + Circle | Red
| Select + Square | Magenta
| Select + Triangle | Green
| Select + Cross | Blue
| Select + Move | White
| Select + Start | Yellow
| Select + T(rigger) | Cyan
| Select + PS | Off |
Tips on action video
Now, the tips:
- For a more natural movement of hands you can attach motion controllers to outer side of hands with tape instead of holding.
- The recommended location for a motion controller on the head is at the top, with controller's top (light sphere for PS Move) looking forward.
- To aim at camera with on-head controller (which you can't see), move the head slowly within a reasonable range from assumed direction to a camera. Then you'll select a frame with the most appropriate direction in iPi Mocap Studio.
- Write down which motion controller corresponds to which body part, by their order in iPi Recorder.
Tracking
There is a tab in iPi Mocap Studio named Motion Controllers. It is visible only when open project contains data from one or more motion controllers. Dealing with this data makes sense only after the tracking of the body is complete. In case of several controllers, data from each of the controllers is processed separately in any convenient order. Numbering of controllers correspond to their order in iPi Recorder when a video was recorded.
When a project with motion data is first created, you will see this data as one or more colored "bricks" floating somewhere under the actor's model. The color is used to differentiate motion controllers in the scene. You can change the for each controller color on the Motion Controllers tab.
And finally — applying the motion controller's data to the bone rotation. First, determine you region of interest. Ensure that within this region of frames the actor maintains a fixed grip of the controller. Frames with different grip should be processed separately. Next, select some frame within the region where the orientation of actor's bone is well visible on video. Edit the orientation of model's bone with the Rotate tool to correspond to the video. When ready, press the Apply Motion Data button — and in all frames within ROI, the bone's orientation will be set automatically according to relative orientation of bone and controller in the current frame.
Recommended Workflow
- Perform Tracking.
- Perform Manual Clean-up if necessary.
- Apply motion controllers' data according to instruction above
- Perform Refine
- Perform Jitter Removal
- Apply motion controllers' data once more according to instruction above
Tutorials and demos
- Video of pairing procedure for PS Move:
