Motion Controllers
Revision as of 08:17, 10 September 2018 by Vmaslov (Talk | contribs)
Equipment
PlayStation Move
Wii Remote with MotionPlus
Wii Remote Plus
  • PlayStation Move
  • Wii Remote with MotionPlus
Note: It is required that Bluetooth adapter supports specification Bluetooth 2.1 with EDR. However, more modern adapters which support Bluetooth 3.0 or 4.0 are not guaranteed to work with PS Move or Wii Remote. To be on the safe side, use adapter capable of exactly BT 2.1 EDR, not greater.
Prefer Class 1 adapters as they have extended range of operation (up to 100m).
iPi Recorder does not limit the number of connected motion controllers. However, the hardware does. Most Bluetooth adapters can handle up to 4 PS Move controllers (sometimes more). iPi Software supports up to 3 controllers for each actor. Thus, additional Bluetooth adapter(s) would be required. Unfortunately, standard Windows Bluetooth drivers do not support multiple adapters. We used to recommend Motion in Joy drivers that allowed support for multiple adapters, but these drivers are now out of support and thus not available anymore. However, if you use Distributed Recording, you can use multiple adapters (one adapter per computer).
For PS Move, an USB to mini-USB cable is also required to charge your motion controller and for pairing (see next section).
Barcodes of different makes of PS Move
Tip: Unless you already have Wii stuff, we strongly recommend to use PlayStation Move, because of its built-in magnetometer. In short, the presence of magnetometer gives a lot more stable orientation value. Without it, orientation tends to drift around vertical axis, and this leads to less accurate measurements.
Unfortunately, the latest makes of PS Move do not have a magnetometer. So when buying PS Moves, try to get ones branded for PlayStation 3 console, maybe used. Some earlier PS Moves branded for PlayStation 4 may also have a magnetometer, because we started to see no magnetic data only in the end of 2016. But we do not have 100% evidence of this.
Looking at a barcode on the back label of a controller can help to distinguish between different makes. For instance, all PS Moves without magnetometer we've seen so far have a barcode starting with a digit 4. For comparison, barcodes of PS Moves which have magnetometer can start, for instance, with GS3 or 1.
Recording
To get your motion controller in the list of devices, it must be connected to a PC via Bluetooth. But before it can connect to your Bluetooth adapter, the controller must be paired with it. For that, press the Add Controller button in the toolbar, select device type you have, and then follow the instructions specific for this device.
Tip: You can use motion controller to start/stop recording (including background evaluation). Just hold PS Move's Start button, or Wiimote's A button for a few seconds, until you feel a vibration.
Buttons Color
Select + Circle
Red
Select + Square
Magenta
Select + Triangle
Green
Select + Cross
Blue
Select + Move
White
Select + Start
Yellow
Select + T(rigger)
Cyan
Select + PS Off
Tips on action video
Aiming at a camera
Standard grip
Now, the tips:
Tracking
Aligning to the scene
Applying motion data
Recommended Workflow
  1. Perform Tracking.
  3. Apply motion controllers' data according to instruction above
  4. Perform Refine
  5. Perform Jitter Removal
  6. Apply motion controllers' data once more according to instruction above
Tutorials and demos
