Motion Controllers
- Wrist rotations can be tracked only with motion controllers due to low resolution of video.
- Though head can be tracked with camera, using a motion controller for that purpose greatly reduces the processing time and may provide better accuracy.
Equipment
- PlayStation Move
- Wii Remote with MotionPlus
Prefer Class 1 adapters as they have extended range of operation (up to 100m).
iPi Recorder does not limit the number of connected motion controllers. However, the hardware does. Most Bluetooth adapters can handle up to 4 PS Move controllers (sometimes more). iPi Software supports up to 3 controllers for each actor. Thus, additional Bluetooth adapter(s) would be required. Unfortunately, standard Windows Bluetooth drivers do not support multiple adapters. We used to recommend Motion in Joy drivers that allowed support for multiple adapters, but these drivers are now out of support and thus not available anymore. However, if you use Distributed Recording, you can use multiple adapters (one adapter per computer).
For PS Move, an USB to mini-USB (model CECH-ZCM1x) or micro-USB (model CECH-ZCM2x) cable is also required to charge your motion controller and for pairing (see next section).
- Older models feature built-in magnetometer. In short, the presence of magnetometer gives a lot more stable orientation value. Without it, orientation tends to drift around vertical axis, and this leads to less accurate measurements.
- It does not need to be paired on each usage.
- Its lighting sphere can be used for scene calibration with the light marker technique.
Recording
To get your motion controller in the list of devices, it must be connected to a PC via Bluetooth. But before it can connect to your Bluetooth adapter, the controller must be paired with it. For that, press the Add Controller button in the toolbar, select device type you have, and then follow the instructions specific for this device.
| Buttons | Color |
| Select + Circle | Red
| Select + Square | Magenta
| Select + Triangle | Green
| Select + Cross | Blue
| Select + Move | White
| Select + Start | Yellow
| Select + T(rigger) | Cyan
| Select + PS | Off |
Tips on action video
Now, the tips:
- For a more natural movement of hands you can attach motion controllers to outer side of hands with tape instead of holding.
- The recommended location for a motion controller on the head is at the top, with controller's top (light sphere for PS Move) looking forward.
- To aim at camera with on-head controller (which you can't see), move the head slowly within a reasonable range from assumed direction to a camera. Then you'll select a frame with the most appropriate direction in iPi Mocap Studio.
- Write down which motion controller corresponds to which body part, by their order in iPi Recorder.
Tracking
Aligning to the scene
Applying motion data
Recommended Workflow
- Perform Tracking.
- Perform Manual Clean-up if necessary.
- Align controllers to the scene and Apply motion data
- Perform Refine
- Perform Jitter Removal
- Apply motion data
Tutorials and demos
- Video of pairing procedure for PS Move:
