iPi Recorder Installation
Revision as of 09:28, 5 February 2019 by Vmaslov (Talk | contribs)
  1. Select needed components
Important!
Components
  • (Windows 8, 8.1, 10) Microsoft Kinect 2:: MS Kinect SDK 2.0. Check if you plan to work with Kinect 2 for Windows or Kinect for Xbox One depth sensors, but do not plan to connect multiple Kinects to a single PC.
    Device drivers and software libraries for Microsoft Kinect 2. Requires 64-bit Windows 8+ and USB 3.0.
    iPi Recorder itself.
