iPi Recorder User's Guide
Revision as of 12:15, 6 February 2019 by Vmaslov (Talk | contribs)
General UI Layout
UI Layout
Home View
Home View
  • Add Device allows to make a connection between motion controllers and PC or enable support for particular camera type.
  • Camera Types shows whether specific camera types are supported on this system and enabled, and what should be done to add the support.
Tip: The program stores your last selection. Thus, if you have not disconnected devices since the last run, the selection will most probably restore automatically.
On the right there is a list of videos which have been recently recorded or played. Just click on an item to open this video for playback and/or editing. You can also press the Browse button to select a file to open with the file dialog.
Recording Workflow
Setup
Setup view allows to adjust device and screen settings before recording.
Setup View
You can:
  • Select working video mode
  • Select microphone and audio mode
  • Adjust number of cameras displayed in a grid row to optimize screen space usage
  • Reorder devices within a grid.
  • Select display layout for depth sensors screens when both depth and color are present.
  • Set global properties for a group of similar devices, if there are any.
    Example of such property is Darkening for Calibration for PS Eye cameras. Global properties are found in the Shared Settings group in the ribbon.
    Examples of such properties include brightness and contrast for color cameras, and elevation angle for Kinects. To access individual device properties, press the Properties button in the device's screen overlay.
Background
Background View
Record
Record View
  • None
  • Background subtraction
    Lossless computational-inexpensive compression. Provides compression ratio in the range 2..10 approximately. A trade-off between CPU and storage.
  • JPEG (for color only)
    Lossy computational-expensive compression. Provides compression ratio up to 100 and more, depending on value of the Quality setting. The highest load of CPU, and the lowest load of storage.
    Note: Use with caution for color cameras. Lossy compression reduces the quality of the image, and may lead to more tracking errors. If you are forced to use it due to limited disk space/speed, leave the quality value at considerably high level. We recommend 70 and more.
  • How well an actor is distinguished from the background. For instance, if shirt color is close to the color of walls, then an actor may blend with the background and this will spoil tracking.
  • Whether background has changed substantially and needs to be re-evaluated. Another indication of this fact is a low percentage of background area in camera statistics. It is highlighted with red in this case.
The Refresh button reinitializes all the devices without leaving to the Home view. This helps in case of temporary hardware glitches.
Also, the ribbon contains controls related to live streaming and distributed recording.
Recording View
Recording Results
Editing and Export
iPi Recorder is capable of simple editing of recorded .iPiVideo files as well as exporting data to regular media files. To use these features switch to the Edit view when a video is open for playback.
Important! Edit and export features require an active license for iPi Mocap Studio on the same PC. The same limitations on camera configuration are applied as for tracking. For instance, if you have the Basic license, then you can edit/export videos with up to 6 color cameras or up to 2 depth sensors.
Edit View
Editing is essentially saving a subset of originally recorded data to the same or to another .iPiVideo file. There are two options to define a subset of video data to be used for save/export, which you can use separately or combined:
  1. Exclude data from some of the devices.
    Click on a device screen to select/unselect data from this device. Or use commands in the ribbon to perform group selection operations.
    Tip: This option is particularly useful when one of the cameras spoils tracking but you don't want to throw away the whole video. For example, the camera was moved during recording so its position in the scene is not accurate. Or the colors in that camera differ too much from other cameras.
  2. Select an interval of frames.
    Use controls in the Interval group in the ribbon or markers on the timeline to set interval boundaries.
    Tip: This option is useful for trimming useless data from both ends of the video. If a video contains multiple takes, it may be convenient to save them into separate .iPiVideo files.
After you have selected the data to use, hit the Save button to replace the original file, or Save As to save the data to another file.
Video export produces an .avi video file from color streams of selected cameras or depth sensors. Besides selecting devices to export (and a frame interval if needed) you should take care of a couple of other things:
  • Video codec used to encode a resulting video.
    iPi Recorder supports Motion JPEG (built-in), Xvid (if installed, on 32-bit OS only) and x264vfw (if installed).
  • When multiple screens are selected, choose how they are composed into a single video frame.
Press the Export Video button to select a destination file and run the export.
You can also export:
  • Depth data to series of 16-bit grayscale PNG images. Pixel values represent depth in millimeters.
  • Audio data to a .wav audio file.
Additional Resources
Real-time streaming
How to Calibrate Camera Optics
How to Build Synced Multi-Camera Video
