Motion Controllers
Revision as of 06:13, 22 March 2019 by Vmaslov (Talk | contribs)
Equipment
Model Bluetooth Spec Advantages Disadvantages Comments
PlayStation Move
Bluetooth 2.1 EDR
Not sure of CECH-ZCM2x
  • Has magnetometer in older makes of CECH-ZCM1x which prevents drift of orientation around vertical axis
  • Lighting sphere can be used for scene calibration with the light marker technique
  • Most bulky dimensions
  • USB cable is required for charging and pairing (mini-USB for CECH-ZCM1x and micro-USB for CECH-ZCM2x)
Nintendo Joy-Con
Bluetooth 3.0
  • Most compact dimensions
  • Switch console or Joy-Con Grip is required for charging
Wii Remote with Motion Plus
Bluetooth 2.1 EDR
  • Needs to be paired on each usage
  • Powered by common AA batteries
Important! For PS Move and Wii Remote, it is required that Bluetooth adapter supports specification Bluetooth 2.1 with EDR. However, more modern adapters which support Bluetooth 3.0 or 4.0 are not guaranteed to work with PS Move or Wii Remote. To be on the safe side, use adapter capable of exactly BT 2.1 EDR, not greater.
Important! For Nintendo Joy-Con, Bluetooth adapter should support Bluetooth 3.0 specification. Bluetooth 4.0 adapters (downwards compatible with 3.0) usually work as well.
iPi Recorder does not limit the number of connected motion controllers. However, the hardware does. Most Bluetooth adapters can handle up to 4 PS Move controllers (sometimes more). iPi Software supports up to 3 controllers for each actor. Thus, additional Bluetooth adapter(s) would be required. Unfortunately, standard Windows Bluetooth drivers do not support multiple adapters. We used to recommend Motion in Joy drivers that allowed support for multiple adapters, but these drivers are now out of support and thus not available anymore. However, if you use Distributed Recording, you can use multiple adapters (one adapter per computer).
Barcodes of different makes of PS Move
Tip: There are several makes of PS Move featuring different IMU chips. The oldest CECH-ZCM1x have a magnetometer, the newer CECH-ZCM1x and CECH-ZCM2x do not. From our experience, CECH-ZCM1x without magnetometer features substantial drift around vertical axis, while CECH-ZCM2x has good enough measurement. So we recommend either an older CECH-ZCM1x or CECH-ZCM2x. To distinguish between the makes, first look at the model number in the top right. For model CECH-ZCM1x (mini-USB connector) look at the barcode. If it starts with the digit 4 then most likely it does not have a magnetometer. Barcodes of CECH-ZCM1x having magnetometer can start, for instance, with GS3 or 1.
Recording
Tip: When pairing newer PS Move model CECH-ZCM2x (with micro-USB connector) you'll see a notification from Windows about adding a new device.
Notification on Windows 10
Pair dialog on Windows 10
Tip: You can use motion controller to start/stop recording (including background evaluation). Just hold PS Move's Start button, or Wiimote's A button for a few seconds, until you feel a vibration.
Buttons Color
Select + Circle
Red
Select + Square
Magenta
Select + Triangle
Green
Select + Cross
Blue
Select + Move
White
Select + Start
Yellow
Select + T(rigger)
Cyan
Select + PS Off
Tips on action video
Aiming at a camera
Standard grip
Now, the tips:
Tracking
Aligning to the scene
Applying motion data
Recommended Workflow
  1. Perform Tracking.
  4. Perform Refine
  5. Perform Jitter Removal
  6. Apply motion data
Head Rotation
Tutorials and demos
