Motion Controllers
Revision as of 08:13, 22 March 2019 by Vmaslov (Talk | contribs)
Equipment
Model Bluetooth Spec Advantages Disadvantages Comments
PlayStation Move
Bluetooth 2.1 EDR
Not sure of CECH-ZCM2x
  • Has magnetometer in older makes of CECH-ZCM1x which prevents drift of orientation around vertical axis
  • Lighting sphere can be used for scene calibration with the light marker technique
  • Most bulky dimensions
  • USB cable is required for charging and pairing (mini-USB for CECH-ZCM1x and micro-USB for CECH-ZCM2x)
Nintendo Joy-Con
Bluetooth 3.0
  • Most compact dimensions
  • Switch console or Joy-Con Grip is required for charging
Wii Remote with Motion Plus
Bluetooth 2.1 EDR
  • Needs to be paired on each usage
  • Powered by common AA batteries
Important! Each motion controller requires specific version of Bluetooth protocol. Usually adapters supporting higher versions are also compatible with lower version devices. However, this is not always the case. For instance, many BT 3.0/4.0 adapters do not work with PS Move which requires BT 2.1 EDR. So if you're buying an adapter specifically for use with motion controllers, it may be safer to get one supporting exactly version of Bluetooth required by a particular motion controller.
Recording
Notification on Windows 10
Pair dialog on Windows 10
Buttons Color
Select + Circle
Red
Select + Square
Magenta
Select + Triangle
Green
Select + Cross
Blue
Select + Move
White
Select + Start
Yellow
Select + T(rigger)
Cyan
Select + PS Off
Tips on action video
Aiming at a camera
Standard grip
Now, the tips:
Tracking
Aligning to the scene
Applying motion data
Recommended Workflow
  1. Perform Tracking.
  4. Perform Refine
  5. Perform Jitter Removal
  6. Apply motion data
Head Rotation
Tutorials and demos
