Motion Controllers
- Wrist rotations can be tracked only with motion controllers due to low resolution of video.
- Though head can be tracked with camera, using a motion controller for that purpose greatly reduces the processing time and may provide better accuracy.
Equipment
| Model | Bluetooth | Magnetometer | Battery Life / Charging | Comments |
PlayStation Move (model CECH-ZCM1x, older) |
Bluetooth 2.1 EDR | + | 10 hours Charged with mini-USB cable |
PlayStation Move (model CECH-ZCM1x, newer) |
Bluetooth 2.1 EDR | - | 10 hours Charged with mini-USB cable |
PlayStation Move (model CECH-ZCM2x) |
? Tested with ASUS USB-BT400 adapter (Bluetooth 4.0) |
- | 10+ hours (capacity increased compared to CECH-ZCM1x) Charged with micro-USB cable |
Nintendo Joy-Con |
Bluetooth 3.0 | - | 20 hours Charged by attaching to Switch console or Joy-Con grip |
Wii Remote with Motion Plus |
Bluetooth 2.1 EDR | - | 20-30 hours 2x AA batteries |
Wii Remote Plus (with Motion Plus integrated) |
Recording
| Buttons | Color |
| Select + Circle | Red
| Select + Square | Magenta
| Select + Triangle | Green
| Select + Cross | Blue
| Select + Move | White
| Select + Start | Yellow
| Select + T(rigger) | Cyan
| Select + PS | Off |
Tips on action video
Now, the tips:
- For a more natural movement of hands you can attach motion controllers to outer side of hands with tape instead of holding.
- The recommended location for a motion controller on the head is at the top, with controller's top (light sphere for PS Move) looking forward.
- To aim at camera with on-head controller (which you can't see), move the head slowly within a reasonable range from assumed direction to a camera. Then you'll select a frame with the most appropriate direction in iPi Mocap Studio.
- Write down which motion controller corresponds to which body part, by their order in iPi Recorder.
Tracking
Aligning to the scene
Applying motion data
Recommended Workflow
- Perform Tracking.
- Perform Manual Clean-up if necessary.
- Align controllers to the scene and Apply motion data
- Perform Refine
- Perform Jitter Removal
- Apply motion data
Head Rotation
Tutorials and demos
- Video of pairing procedure for PS Move:
