Motion Controllers
Revision as of 09:30, 22 March 2019 by Vmaslov (Talk | contribs)
Equipment
Model Bluetooth Magnetometer Battery Life / Charging Comments
Bluetooth 2.1 EDR + 10 hours
Charged with mini-USB cable
Bluetooth 2.1 EDR - 10 hours
Tested with ASUS USB-BT400 adapter (Bluetooth 4.0)
- 10+ hours (capacity increased compared to CECH-ZCM1x)
Charged with micro-USB cable
Nintendo Joy-Con
Bluetooth 3.0 - 20 hours
Charged by attaching to Switch console or Joy-Con grip
  • Most compact dimensions
Wii Remote with Motion Plus
Bluetooth 2.1 EDR - 20-30 hours
2x AA batteries
  • Batteries are consumed even when off. So put them out when device is not used for a long period.
2x AA batteries
Important! Each motion controller requires specific version of Bluetooth protocol. Usually adapters supporting higher versions are also compatible with lower version devices. However, this is not always the case. For instance, many BT 3.0/4.0 adapters do not work with PS Move which requires BT 2.1 EDR. So if you're buying an adapter specifically for use with motion controllers, it may be safer to get one supporting exactly version of Bluetooth required by a particular motion controller.
Note: A magnetometer improves the accuracy of output orientation in the long run by preventing its drift around vertical axis. However, this comes with downsides. First, considering magnetometer measurements makes output orientation to react to actual motions a bit slower. Second, magnetometer measurements depend on environment. Thus, for fast motions and areas with high elecromagnetic noise PS Move with magnetometer may not work well.
Recording
Notification on Windows 10
Pair dialog on Windows 10
Buttons Color
Select + Circle
Red
Select + Square
Magenta
Select + Triangle
Green
Select + Cross
Blue
Select + Move
White
Select + Start
Yellow
Select + T(rigger)
Cyan
Select + PS Off
Tips on action video
Aiming at a camera
Standard grip
Now, the tips:
Tracking
Aligning to the scene
Applying motion data
Recommended Workflow
  1. Perform Tracking.
  4. Perform Refine
  5. Perform Jitter Removal
  6. Apply motion data
Head Rotation
Tutorials and demos
