Motion Controllers
Revision as of 02:36, 8 January 2021 by Vmaslov (Talk | contribs)
Equipment
Model Bluetooth Magnetometer Measurement Rate Battery Life / Charging Comments
Bluetooth 2.1 EDR
120 Hz 10 hours
Charged with mini-USB cable
Bluetooth 2.1 EDR
120 Hz 10 hours
Tested with ASUS USB-BT400 adapter (Bluetooth 4.0)
1200 Hz
10 times faster than CECH-ZCM1x
10+ hours
No official number but battery is known to have greater capacity than CECH-ZCM1x
Charged with micro-USB cable
Nintendo Joy-Con
Bluetooth 3.0
200 Hz 20 hours
Charged by attaching to Switch console or Joy-Con grip
  • Most compact dimensions
Wii Remote with Motion Plus
Bluetooth 2.1 EDR
100 Hz 20-30 hours
2x AA batteries
  • Batteries are consumed even when off. So take them out when device is not used for a long period.
Bluetooth 2.1 EDR
100 Hz 20-30 hours
2x AA batteries
Important! Each motion controller requires specific version of Bluetooth protocol. Usually adapters supporting higher versions are also compatible with lower version devices. However, this is not always the case. For instance, many BT 3.0/4.0 adapters do not work with PS Move CECH-ZCM1x model which requires BT 2.1 EDR. So if you're buying an adapter specifically for use with motion controllers, it may be safer to get one supporting the exact version of Bluetooth required by a particular motion controller.
Note: A magnetometer improves the accuracy of output orientation in the long run by preventing its drift around vertical axis. However, this comes with downsides. First, magnetometer introduces sometimes noticeable delay in the response of output orientation to actual motions. Second, magnetometer measurements depend on environment. Thus, for fast motions and areas with high elecromagnetic noise PS Move with magnetometer may not work well.
Recording
Notification on Windows 10
Pair dialog on Windows 10
Buttons Color
Select + Circle
Red
Select + Square
Magenta
Select + Triangle
Green
Select + Cross
Blue
Select + Move
White
Select + Start
Yellow
Select + T(rigger)
Cyan
Select + PS Off
Tips on action video
Aiming at a camera
Standard grip
There is one main requirement:
Now, the tips:
  • If you want to see a natural orientation of prop models like the sword or the pistol in iPi Mocap Studio, hold the controller with its buttons facing the actor's face when an arm with a controller is stretched forward. We call it a "standard" grip (see picture).
Tracking
Aligning to the scene
Applying motion data
Recommended Workflow
  1. Perform Tracking.
  4. Perform Refine
  5. Perform Jitter Removal
  6. Apply motion data
Head Rotation
Tutorials and demos
