Depth Sensors Comparison
Revision as of 06:33, 30 October 2014 by Andrew (Talk | contribs)
Kinect Sensors Support
iPi Recorder supports Kinect 2 and Kinect sensors. Kinect 2 for Windows and Kinect for Xbox One is the same sensor. Kinect 2 has higher resolution compared to first generation Kinect sensor.
Important! Only single Kinect 2 sensor is supported due to limitation in Microsoft Kinect SDK 2. Using multiple Kinect 2 sensors will soon be possible with the help of distributed recording feature, which will allow to record the same session with several computers. In this case each Kinect 2 sensor can be connected to a separate computer.
Kinect for Xbox One
Microsoft Kinect for Windows
Kinect Sensros Comparison
Device Pros Cons
Kinect 2 for Windows / Kinect for Xbox One
  • Higher resolution of depth and RGB video
  • Low mutual sensors interference
  • More tolerant to lighting conditions
  • Better tracking quality can be expected
    (but the difference with first generation Kinect is not dramatic)
  • Requires USB 3.0 controller
  • Only single sensor on one PC is supported by Microsoft Kinect SDK 2
  • Works only on Windows 8 / 8.1
Kinect for Windows
  • Ensures tracking quality comparable with Kinect 2, but hardware requirements are not so strong
  • Requires USB 2.0 controller
  • Works on Windows 8 / 7 / Vista SP2
  • Lower resolution
  • Less tolerant to lighting conditions
  • Higher mutual interference of sensors leads to more noise in case of using several sensors
Obsolete Sensors
iPi Recorder also supports obsolete sensors, currently unavailable for purchase:
ASUS Xtion Live
ASUS Xtion
PrimeSense Carmine 1.08
If needed you can find more information about these sensors in documentation for previous version of iPi Motion Capture.
