Multiple PS Eye Cameras Calibration
Revision as of 03:46, 30 October 2024 by Pavel (Talk | contribs)
Flashlight Calibration
Importance of high frame rate
Glowing Marker
Step 1: Running iPi Recorder in Calibration Mode
Step 2: Record Calibration Video
Start video recording.
Tip: For successful calibration, several hundred frames are sufficient. Much more frames (like several thousands) will not produce more accurate results, but instead will increase the processing time and possible number of marker detection errors. So generally it is not recommended to record calibration videos of more than 1 minute length.
Tip: You should make the marker visible to as much cameras as possible at all times. Hold the marker in the straight arm away from your body. In a circle configuration, when approaching the boundary of the capture area, position the marker inside the area, and your body outside.
Step 3: Stop Recording and Check Recorded Video
  • Most of the time (80%-90% of all recording time) marker is visible in all cameras
Step 4: Take Note of Height of Your First Camera Over the Ground.
Step 5: Process Calibration Video in iPi Mocap Studio
Tip: You can postpone processing calibration video until after you finished recording other videos (e.g. your action videos). However, it is a good idea to process your calibration video as soon as it was recorded because it helps you ensure that you have good calibration. Use Regular calibration mode (1) if you want to be 100% sure that calibration sequence is fine. Also you can use Fast calibration mode to save time. But in this case you will need to re-process calibration video later to get maximum calibration quality. I certain cases Fast calibration mode can fail to calibrate even if calibration sequence is fine and can be calibrated successfully in Regular calibration mode.
    • Press New button or select File > New Project menu item or use Ctrl+N (2)
    • Set the diagonal Field of View (FOV) for your cameras.
    Note: If you use Sony PS Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
  • Adjust the Region-of-Interest to cover the part of video that contains the glowing marker (3).
  • Normally, you need to use default calibration settings
    • Auto-detect initial camera positions turned on
      • If calibration fails to detect initial camera positions correctly, you can turn this checkbox off and set camera positions manually. But in most cases it will be easier to re-record calibration sequence.
    • Auto-adjust camera FOV turned off
      • Use this mode only if you do not use Sony PS3 Eye camera and do not know camera field of view
    • Regular calibration mode
      • In rare cases when Regular mode fails to calibrate, you can use Extended and Extreme calibration modes. It will take much more time, but may help to calibrate correctly if you have high percent of marker misdetections. Usually this is caused by incorrect camera positioning or poor lighting conditions
  • Click Calibrate button and wait while the system finishes calibration (4).
Step 6: Check Calibration Quality
Important! Failed calibration is not recommended to use, as you will not be able to get accurate tracking results. However, sometimes Failed status can be misdetected. If detected marker positions are close to marker image on video in all frames for all sensors, you can use this calibration for tracking.
Step 7: Check Ground Plane
Manual Floor Detection
  • Make sure that ground points are actually near the ground plane.
  • If ground plane is detected incorrectly, select ground points manually.
    • Expand Manual Calibration Adjustment expander.
    • First, unmark all ground points by pressing Clear all points button.
    • For each ground point, click on it in 3D view and press Mark as ground button.
    • You can cancel marking point as ground point by pressing Unmark ground button.
Important! If you do not mark ground points then the ground plane is incorrect and there is no sense in using Foot tracking option and camera heights values.
Step 8: Set Scene Scale Using Camera Height as Reference
