Multiple PS Eye Cameras Calibration
- 1 Flashlight Calibration
- 1.1 Importance of high frame rate
- 1.2 Glowing Marker
- 1.3 Step 1: Running iPi Recorder in Calibration Mode
- 1.4 Step 2: Record Calibration Video
- 1.5 Step 3: Stop Recording and Check Recorded Video
- 1.6 Step 4: Take Note of Height of Your First Camera Over the Ground.
- 1.7 Step 5: Process Calibration Video in iPi Mocap Studio
- 1.8 Step 6: Check Calibration Quality
- 1.9 Step 7: Check Ground Plane
- 1.10 Step 8: Set Scene Scale Using Camera Height as Reference
- 2 Calibration Based on AI Joints
- 2.1 Importance of high frame rate
- 2.2 Step 1: Running iPi Recorder
- 2.3 Step 2: Record Calibration Video
- 2.4 Step 3: Take Note of Height of Your First Camera Over the Ground.
- 2.5 Step 4: Process Calibration Video in iPi Mocap Studio
- 2.6 Step 6: Check Calibration Quality
- 2.7 Step 7: Check Ground Plane
- 2.8 Step 8: Set Scene Scale Using Camera Height as Reference
Glowing Marker
Start video recording.
- Most of the time (80%-90% of all recording time) marker is visible in all cameras
- Create new calibration project in iPi Mocap Studio:
- Press New button or select File > New Project menu item or use Ctrl+N (2)
- Choose Calibration project type in New Project Wizard.
- Set the diagonal Field of View (FOV) for your cameras. If this screen is not shown, this means FOV is already known and you do not need to manually specify it.
- Note: If you use Sony PS Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
- Adjust the Region-of-Interest to cover the part of video that contains the glowing marker (3).
- Normally, you need to use default calibration settings
- Auto-detect initial camera positions turned on
- If calibration fails to detect initial camera positions correctly, you can turn this checkbox off and set camera positions manually. But in most cases it will be easier to re-record calibration sequence.
- Auto-adjust camera FOV turned off
- Use this mode only if you did not know camera field of view requested during project creation (if it was requested) or if it was set by default (this may be recommended for particular camera models).
- Click Calibrate Based on Flashlight Marker button and wait while the system finishes calibration (4).
- Expand Manual Calibration Adjustment expander.
- First, unmark all ground points by pressing Clear all points button.
- For each ground point, click on it in 3D view and press Mark as ground button.
Just walk around the whole capture area, and put hands up from time to time.
- Adjust the Region-of-Interest to cover the part of video that contains movement around capture area.
- Click Calibrate Based on AI Joints button and wait while the system finishes calibration (4).
