Multiple PS Eye Cameras Calibration
Revision as of 05:30, 31 October 2024 by Pavel (Talk | contribs)
Flashlight Calibration
Importance of high frame rate
Glowing Marker
Step 1: Running iPi Recorder in Calibration Mode
Step 2: Record Calibration Video
Start video recording.
Tip: For successful calibration, several hundred frames are sufficient. Much more frames (like several thousands) will not produce more accurate results, but instead will increase the processing time and possible number of marker detection errors. So generally it is not recommended to record calibration videos of more than 1 minute length.
Tip: You should make the marker visible to as much cameras as possible at all times. Hold the marker in the straight arm away from your body. In a circle configuration, when approaching the boundary of the capture area, position the marker inside the area, and your body outside.
Step 3: Stop Recording and Check Recorded Video
  • Most of the time (80%-90% of all recording time) marker is visible in all cameras
Step 4: Take Note of Height of Your First Camera Over the Ground.
Step 5: Process Calibration Video in iPi Mocap Studio
Tip: You can postpone processing calibration video until after you finished recording other videos (e.g. your action videos). However, it is a good idea to process your calibration video as soon as it was recorded because it helps you ensure that you have good calibration.
    • Press New button or select File > New Project menu item or use Ctrl+N (2)
    • Set the diagonal Field of View (FOV) for your cameras. If this screen is not shown, this means FOV is already known and you do not need to manually specify it.
    Note: If you use Sony PS Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
  • Adjust the Region-of-Interest to cover the part of video that contains the glowing marker (3).
  • Change the size of light marker spot on video if needed.
    • Medium usually work well, but you may need Large if you use Sony PS Move for calibration, or Small in some cases.
  • Normally, you need to use default calibration settings
    • Auto-detect initial camera positions turned on
      • If calibration fails to detect initial camera positions correctly, you can turn this checkbox off and set camera positions manually. But in most cases it will be easier to re-record calibration sequence.
    • Auto-adjust camera FOV turned off
      • Use this mode only if you did not know camera field of view requested during project creation (if it was requested) or if it was set by default (this may be recommended for particular camera models).
  • Click Calibrate Based on Flashlight Marker button and wait while the system finishes calibration (4).
Step 6: Check Calibration Quality
Important! Failed calibration is not recommended to use, as you will not be able to get accurate tracking results. However, sometimes Failed status can be misdetected. If detected marker positions are close to marker image on video in all frames for all sensors, you can use this calibration for tracking.
Step 7: Check Ground Plane
Manual Floor Detection
  • Make sure that ground points are actually near the ground plane.
  • If ground plane is detected incorrectly, select ground points manually.
    • Expand Manual Calibration Adjustment expander.
    • First, unmark all ground points by pressing Clear all points button.
    • For each ground point, click on it in 3D view and press Mark as ground button.
    • You can cancel marking point as ground point by pressing Unmark ground button.
Important! If you do not mark ground points then the ground plane is incorrect and there is no sense in using Foot tracking option and camera heights values.
Step 8: Set Scene Scale Using Camera Height as Reference
Calibration Based on AI Joints
Just walk around the whole capture area, and put hands up from time to time.
Tip: The exact movement is not so important, just try to cover the whole capture volume by arms and legs movement, or at least its perimeter.
Tip: You can use your action videos for calibration, if the body movement cover the whole capture area. Videos when you stand at the same place all the time will not allow for accurate calibration.
Tip: For successful calibration, 1000 frames shoud be enough. Recording long videos over 1 minute length does not make much sense, but you still can use them for calibration.
Step 3: Take Note of Height of Your First Camera Over the Ground.
  • Adjust the Region-of-Interest to cover the part of video that contains movement around capture area.
  • Click Calibrate Based on AI Joints button and wait while the system finishes calibration (4).
Complete Calibration
