iPi Recorder Installation
- Select needed components
- You can plug only one depth sensor to one USB controller. Single USB controller bandwidth is not enough to record from 2 sensors.
Components
- Microsoft .NET Framework 4.5.1 - Client. This is required component and cannot be unchecked.
This is basic infrastructure for running .NET programs. iPi Recorder is a .NET program.- Web installer: http://www.microsoft.com/en-us/download/details.aspx?id=40773
- Standalone installer: http://www.microsoft.com/en-us/download/details.aspx?id=40779
- (Windows 8) Microsoft Kinect 2:: MS Kinect SDK 2.0. Check if you plan to work with Kinect 2 for Windows or Kinect for Xbox One depth sensors.
Device drivers and software libraries for Microsoft Kinect 2. Requires Windows 8 and USB 3.0.
- iPi Recorder 3.x.x.x. This is required component and cannot be unchecked.
iPi Recorder itself.
