Environment
| Configuration | Azure Kinect (WFOV mode) | Azure Kinect (NFOV mode) Kinect 2 (Kinect for Xbox One) |
1st gen. Depth Sensors Orbbec Astra (Pro) |
| Single Depth Sensor |
7 by 5 feet = 2 by 1.5 meters |
8 by 5 feet = 2.5 by 1.5 meters |
10 by 10 feet = 3 by 3 meters |
| 2 Depth Sensors (90-degrees config.) |
7 by 7 feet = 2 by 2 meters |
8 by 8 feet = 2.5 by 2.5 meters |
| 2 Depth Sensors (180-degrees config.) |
12 by 7 feet = 3.5 by 2 meters |
16 by 8 feet = 5 by 2.5 meters |
20 by 10 feet = 6 by 3 meters |
| 3+ Depth Sensors |
12 by 12 feet = 3.5 by 3.5 meters |
16 by 16 feet = 5 by 5 meters |
20 by 20 feet = 6 by 6 meters |
Maximum capture area is about 7 by 7 feet ( = 2 by 2 meters), for all sensor models and configurations.
The pictures below will help you to understand possible capture area and required space. Dimensions are different for Azure Kinect, Kinect 2 (Kinect for Xbox One) and 1st gen. depth sensors due to different field of view.
Azure Kinect in NFOV mode and Kinect 2 for Windows (Kinect for Xbox One)
Kinect 2 (Kinect for Xbox One) sensors and Azure Kinect sensors in NFOV mode (narrow-view mode) have very close view angles (less than Azure Kinect in WFOV mode, but greater than 1st gen. depth sensors and Orbbec Astra):
Wide-view mode (WFOV mode) of Azure Kinect has extremely wide view angle:
First Generation Depth Sensor or Orbbec Astra (Pro)
If you're using outdated 1st generation depth sensor like Kinect v1 or Orbbec Astra (Pro) sensor which is almost the same as 1st gen. depth sensor:
Actor Clothing
Recording Process
Recording Actor's Performance
After completing Setup and Background recording steps, press Record button to begin video recording. To stop recording, press Stop button.
Recommended Layout of an Action Video
- Enter the actor.
- Strike a T-pose.
- Action
T-Pose
As soon as recorder starts, go to the capture area and stand in a T-pose. After that you can act desired motions.
If you make several takes of one actor, we recommend to strike a T-pose in the beginning of each take.
Takes
Iterations
- Record the videos
- Process the videos in iPi Mocap Studio
- Import your target character into iPi Mocap Studio and review the resulting animation
- Give feedback to the actor
Takes
Naming conventions
