Multiple PS Eye Cameras Calibration
- 1 Importance of high frame rate
- 2 Glowing Marker
- 3 Step 1: Running iPi Recorder in Calibration Mode
- 4 Step 2: Record Calibration Video
- 5 Step 3: Stop Recording and Check Recorded Video
- 6 Step 4: Take Note of Height of Your First Camera Over the Ground.
- 7 Step 5: Process Calibration Video in iPi Mocap Studio
- 8 Step 6: Check Ground Plane
- 9 Step 7: Set Scene Scale Using Сamera Height as Reference
Glowing Marker
- Important! Do not turn off the light in the room during calibration! This will not help the software but will make it harder for you to see what is happening on recorded video when you view it later.
Start video recording.
Tip. For successful calibration, several hundred frames are sufficient. Much more frames (like several thousands) will not produce more accurate results, but instead will increase the processing time and possible number of marker detection errors. So generally it is not recommended to record calibration videos of more than 1 minute length.
Tip. You should make the marker visible to as much cameras as possible at all times. Hold the marker in the straight arm away from your body. In a circle configuration, when approaching the boundary of the capture area, position the marker inside the area, and your body outside.
- Load your calibration video to iPi Mocap Studio
- Important. Adjust the Region of Interest to cover the part of video that contains the glowing marker.
- Go to “Calibration” tab. Check “Auto detect initial camera positions” checkbox. Click “Calibrate” button and wait while the system finishes calibration.
- Calibration algorithm may occasionally fail to find correct camera positions. If this happens, you should manually adjust initial camera positions to roughly match your configuration. The main thing is the correct order of the cameras around the capture area, and their approximate view directions.
- Reset camera positions with one of the standard half-circle or full circle configurations that best suits your configuration.
- For each camera that requires adjusting, switch to this camera using the toolbar button, and correct its position using controls on the “Scene” tab.
- Uncheck “Auto detect initial camera positions” checkbox.
- Click “Calibrate” button. This will rerun calibration process, without recomputing marker positions.
- Select the frame where the actor is standing relatively straight.
- Show the model by checking the "View > Skin" menu item.
- Adjust the camera position to fit the model with the actor's image.
Ground plane should be detected automatically. Ground points are marked by yellow color. Make sure that ground points are actually near the ground plane.
If ground plane is detected incorrectly, select ground points manually. For each point, click on it in 3D view and press “Mark as ground” button.
- Make sure you have Good or Perfect calibration result (5).
