Multiple PS Eye Cameras Calibration
- 1 Importance of high frame rate
- 2 Glowing Marker
- 3 Step 1: Running iPi Recorder in Calibration Mode
- 4 Step 2: Record Calibration Video
- 5 Step 3: Stop Recording and Check Recorded Video
- 6 Step 4: Take Note of Height of Your First Camera Over the Ground.
- 7 Step 5: Process Calibration Video in iPi Mocap Studio
- 8 Step 6: Check Calibration Quality
- 9 Step 7: Check Ground Plane
- 10 Step 8: Set Scene Scale Using Сamera Height as Reference
Glowing Marker
Start video recording.
- Most of the time (80%-90% of all recording time) marker is visible in all cameras
- Create new calibration project in iPi Mocap Studio:
- Press New button or select File > New Project menu item or use Ctrl+N (2)
- Choose Calibration project type in New Project Wizard.
- Set the diagonal Field of View (FOV) for your cameras.
- Note: If you use Sony PS Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
- Adjust the Region-of-Interest to cover the part of video that contains the glowing marker (3).
- Click Calibrate button and wait while the system finishes calibration (4).
- Ground plane should be detected automatically. Ground points are marked by yellow color.
- For each point, click on it in 3D view and press Mark as ground button.
