ver. 3.1.1.175
N E W F E A T U R E S:
B U G F I X E S:
- FBX import and export does not support national (non-ASCII) characters in file path.
- Projects for three actors are always created in .iPiLocked format event in Pro edition.
ver. 3.1.0.173
B U G F I X E S:
ver. 3.0.3.172
B U G F I X E S:
- App crash when trying to remove an entry from the list of MRU hand poses
ver. 3.0.2.171
- Options for FBX export:
- FBX version;
- Binary/ASCII format.
- Reduced memory footprint.
B U G F I X E S:
ver. 3.0.1.169
B U G F I X E S:
ver. 3.0.0.166
- Improved calibration:
- more reliable
- faster
- automatic ground detection
- Redesigned user interface.
U N D E R T H E H O O D:
- Migration to DirectX 11.
