Revision as of 11:53, 24 February 2015 by Andrew (Talk | contribs)
ver. 3.1.1.175
Version 3.1.1.175
Feb 24, 2015
Download-24.png  Download
 N E W    F E A T U R E S:
 B U G    F I X E S:
ver. 3.1.0.173
Version 3.1.0.173
Feb 20, 2015
 B U G    F I X E S:
ver. 3.0.3.172
Version 3.0.3.172
Jan 07, 2015
 B U G    F I X E S:
  • App crash when trying to remove an entry from the list of MRU hand poses
ver. 3.0.2.171
Version 3.0.2.171
Nov 26, 2014
  • Options for FBX export:
    • FBX version;
    • Binary/ASCII format.
  • Reduced memory footprint.
 B U G    F I X E S:
ver. 3.0.1.169
Version 3.0.1.169
Nov 11, 2014
 B U G    F I X E S:
ver. 3.0.0.166
Version 3.0.0.166
Nov 03, 2014
  • Improved calibration:
    • more reliable
    • faster
    • automatic ground detection
    • calibration quality feedback
  • Redesigned user interface.
  • Migration to DirectX 11.
