Multiple PS Eye Cameras Calibration
- 1 Importance of high frame rate
- 2 Glowing Marker
- 3 Step 1: Running iPi Recorder in Calibration Mode
- 4 Step 2: Record Calibration Video
- 5 Step 3: Stop Recording and Check Recorded Video
- 6 Step 4: Take Note of Height of Your First Camera Over the Ground.
- 7 Step 5: Process Calibration Video in iPi Mocap Studio
- 8 Step 6: Check Calibration Quality
- 9 Step 7: Check Ground Plane
- 10 Step 8: Set Scene Scale Using Сamera Height as Reference
Glowing Marker
Start video recording.
- Most of the time (80%-90% of all recording time) marker is visible in all cameras
- Create new calibration project in iPi Mocap Studio:
- Press New button or select File > New Project menu item or use Ctrl+N (2)
- Choose Calibration project type in New Project Wizard.
- Set the diagonal Field of View (FOV) for your cameras.
- Note: If you use Sony PS Eye or Logitech QuickCam 9000 cameras, leave the FOV value at the default 75 degrees.
- Adjust the Region-of-Interest to cover the part of video that contains the glowing marker (3).
- Normally, you need to use default calibration settings
- Auto-detect initial camera positions turned on
- If calibration fails to detect initial camera positions correctly, you can turn this checkbox off and set camera positions manually. But in most cases it will be easier to re-record calibration sequence.
- Auto-adjust camera FOV turned off
- Use this mode only if you do not use Sony PS3 Eye camera and do not not camera field of view
- Regular calibration mode
- In rare cases when Regular mode fails to calibrate, you can use Extended and Extreme calibration modes. It will take much more time, but may help to calibrate correctly if you have high percent of marker misdetections. Usually this is caused by incorrect camera positioning or poor lighting conditions
- Click Calibrate button and wait while the system finishes calibration (4).
- For each ground point, click on it in 3D view and press Mark as ground button.
