Background
Revision as of 17:48, 4 March 2015 by Vmaslov (Talk | contribs)
Before you start to record any videos, you'll need to evaluate scene's background. Background is the picture of only static (not moving) objects in the capture area. That means all actors and props they'll manipulate with during an action should be removed from the capture area for the course of background evaluation. Background is embedded into video files and is later used by iPi Mocap Studio to easily detect moving objects. Also, background is employed for compressing videos with the background subtraction method.
