Motion Controllers
Revision as of 10:52, 7 April 2015 by Vmaslov (Talk | contribs)
Note: This article is under construction and will be published in a few days. Meanwhile refer to v2 documentation:
Equipment
PlayStation Move
Wii Remote with MotionPlus
Wii Remote Plus
  • PlayStation Move
  • Wii Remote with MotionPlus
iPi Recorder does not limit the number of connected motion controllers. However, the hardware does. Usually, a single Bluetooth adapter can handle up to 4 PS Move controllers. This is sufficient for a single actor, but for multiple actors you may need more controllers. Thus, additional Bluetooth adapter(s) is required. Unfortunately, standard Windows Bluetooth drivers do not support multiple adapters. To use multiple Bluetooth adapters, it is necessary to install Motion in Joy drivers.
For PS Move, an USB to mini-USB cable is also required to charge your motion controller and for pairing (see next section).
Tip: Unless you already have Wii stuff, we strongly recommend to use PlayStation Move, because of its built-in magnetometer. In short, the presence of magnetometer gives a lot more stable orientation value. Without it, orientation tends to drift around vertical axis, and this leads to less accurate measurements.
Note: On Windows 8 and 8.1, PS Move does not work properly using the standard Bluetooth drivers included with the OS. For these OS versions, it is recommended to install Motion in Joy drivers.
Note: The recent revisions of Wii Remote Plus controllers may not work properly using standard Bluetooth drivers. For them, it is recommended to use Toshiba Bluetooth stack.
