PlayStation Move with Motion in Joy drivers
Revision as of 12:28, 7 April 2015 by Vmaslov (Talk | contribs)
For some reason under Windows 8.x standard pairing procedure with PlayStation Move controllers doesn't work. To resolve this issue iPi Recorder supports Motion in Joy solution as a workaround.
Currently (beginning of 2015) the latest version is 0.7.1001 which can be downloaded from the following direct link: http://www.xinputer.com/download/MotioninJoy_071001_signed.zip
Tip: Alternative download page: http://motioninjoy.en.uptodown.com/
Pairing
Detection in iPi Recorder
Run iPi Recorder. All paired and switched on PS Move devices should be visible and have MotioninJoy logo near device picture:
Further instructions can be found in Motion Controllers article.
Multiple Bluetooth Adapters
To do this:
  • Run DS3 tool
  • Plug in one Bluetooth adapter
  • Install MotioninJoy drivers for it if necessary
  • Pair some PS Moves to this Bluetooth adapter
  • Unplug the Bluetooth adapter
  • Repeat for the next Bluetooth adapter and another portion of PS Moves
  • Plug in all Bluetooth adapters to use. Ensure they all have MotioninJoy drivers installed. This may not be the case if you plugged some of them into different USB ports than when pairing.
  • Exit DS3 tool
  • Turn all PS Moves on. Ensure they all successfully connect to corresponding Bluetooth adapters - red LED glows constantly.
  • Run iPi Recorder. All PS Moves should be listed in Device List.
Notes
N O T E   1:
N O T E   2:
    • click Driver Manager
    • click Roll back
N O T E   3:
N O T E   4:
N O T E   5:
