Motion Controllers
Revision as of 16:26, 8 April 2015 by Vmaslov (Talk | contribs)
Note: This article is under construction and will be published in a few days. Meanwhile refer to v2 documentation:
Equipment
PlayStation Move
Wii Remote with MotionPlus
Wii Remote Plus
  • PlayStation Move
  • Wii Remote with MotionPlus
iPi Recorder does not limit the number of connected motion controllers. However, the hardware does. Usually, a single Bluetooth adapter can handle up to 4 PS Move controllers. This is sufficient for a single actor, but for multiple actors you may need more controllers. Thus, additional Bluetooth adapter(s) is required. Unfortunately, standard Windows Bluetooth drivers do not support multiple adapters. To use multiple Bluetooth adapters, it is necessary to install Motion in Joy drivers.
For PS Move, an USB to mini-USB cable is also required to charge your motion controller and for pairing (see next section).
Tip: Unless you already have Wii stuff, we strongly recommend to use PlayStation Move, because of its built-in magnetometer. In short, the presence of magnetometer gives a lot more stable orientation value. Without it, orientation tends to drift around vertical axis, and this leads to less accurate measurements.
Recording
To get your motion controller in the list of devices, it must be connected to a PC via Bluetooth. But before it can connect to your Bluetooth adapter, the controller must be paired with it. For that, press the Add Controller button in the toolbar, select device type you have, and then follow the instructions specific for this device.
Note: On Windows 8.x, PS Move does not work properly using the standard Bluetooth drivers included with the OS. For these OS versions, it is recommended to install Motion in Joy drivers.
Tip: You can use motion controller to start/stop recording (including background evaluation). Just hold PS Move's Start button, or Wiimote's A button for a few seconds, until you feel a vibration.
Tips on action video
Aiming at a camera
Standard grip
Now, the tips:
Tracking
There is a tab in iPi Mocap Studio named Motion Controllers. It is visible only when open project contains data from one or more motion controllers. Dealing with this data makes sense only after the tracking of the body is complete. In case of several controllers, data from each of the controllers is processed separately in any convenient order. Numbering of controllers correspond to their order in iPi Recorder when a video was recorded.
When a project with motion data is first created, you will see this data as one or more colored "bricks" floating somewhere under the actor's model. The color is used to differentiate motion controllers in the scene. You can change the for each controller color on the Motion Controllers tab.
And finally — applying the motion controller's data to the bone rotation. First, determine you region of interest. Ensure that within this region of frames the actor maintains a fixed grip of the controller. Frames with different grip should be processed separately. Next, select some frame within the region where the orientation of actor's bone is well visible on video. Edit the orientation of model's bone with the Rotate tool to correspond to the video. When ready, press the Apply Motion Data button — and in all frames within ROI, the bone's orientation will be set automatically according to relative orientation of bone and controller in the current frame.
Tutorials and demos
