Frequently Asked Questions
- 1 General Questions
- 2 Product Features
- 2.1 Which configuration do you recommend: Multiple Depth Sensors or Multiple Sony PS Eye?
- 2.2 What is the difference between editions?
- 2.3 Is tracking realtime?
- 2.4 Does iPi Motion Capture support facial mocap?
- 2.5 Can hands be tracked by iPi Motion Capture?
- 2.6 Can fingers be tracked by iPi Motion Capture?
- 2.7 What about head tracking?
- 2.8 What output formats are supported by iPi Motion Capture?
- 2.9 Can I retarget captured animation to my own character?
- 3 Cameras and Depth Sensors
- 3.1 Can I use Kinect for Xbox One or Kinect 2 for Windows with iPi Motion Capture?
- 3.2 Can I use multiple Kinect sensors with iPi Motion Capture?
- 3.3 Is Kinect 2 sensor much better than Kinect?
- 3.4 Do you support ASUS Xtion or PrimeSense Carmine?
- 3.5 Can I mix Kinect with other cameras in multi-camera set-up?
- 3.6 Can I use Kinect and Kinect 2 together?
- 3.7 Can I use USB cameras of different models in multi-camera set-up?
- 3.8 Can I use high-resolution cameras to improve tracking quality?
- 4 Installation and Activation, Licensing policy
- 4.1 Do you offer free trial?
- 4.2 What are trial version limitations?
- 4.3 Can I try the software if I do not have cameras?
- 4.4 How can I install the system?
- 4.5 How can I get and activate the license key for trial?
- 4.6 How can I purchase a full license key?
- 4.7 Is license key time-limited?
- 4.8 Can I install the system on several computers with one license key?
- 4.9 I'm a student now and I'm going to purchase iPi products with educational discount. Can I use the product for commercial project and / or after my graduation?
- 4.10 Can I give my license key to a friend or collegue?
- 4.11 Do I need to pay for new versions of software?
- 4.12 Do I need to pay for Biomech Add-on?
- 5 Purchase FAQ
- 5.1 How can I buy?
- 5.2 Does the price include hardware?
- 5.3 Do you have any discounts?
- 5.4 How can I get volume discount?
- 5.5 Who is eligible for educational discount?
- 5.6 How can I get educational discount?
- 5.7 I'm a student now and I'm going to purchase iPi products with educational discount. Can I use the product for commercial project and / or after my graduation?
- 5.8 I have promotion coupon code. How can I use it?
- 5.9 I want to pay in a currency other than USD. But I found that the currency conversion rate is much higher than what I expected to have. Why is that?
- 6 System Requirements and Hardware
- 7 Biomech Add-on
General Questions
How does it work?
What technical support options are available?
Product Features
There is no straightforward answer to this question, there are pros and cons each option: Multiple Depth Sensors vs Sony PS Eye Comparison.
No, this is not supported.
This is not recommended. For best results all cameras should be the same model. Moreover, we strongly recommend to use Sony PS Eye camera, as it has much better quality for markerless mocap.
No. We do not support them so far. For our software higher resolution does not give much benefit, but highly increases required data bandwidth. As this is markerless technology, we do not need to track small markers, and 640 x 480 resolution will work as good as HD. For motion capture fps (frames per second) is much more critical parameter for tracking accuracy. Sony PS Eye camera, that allows to record at 60 fps with low distortions, is currently most recommended model.
Yes. 30-days free trial is available for download from http://ipisoft.com/download/
Purchase FAQ
How can I buy?
You can buy online: http://ipisoft.com/store. Please find the list of available payment options here.
iPi Soft educational discounted software is available for students, faculty members, and institutions. Please look at http://ipisoft.com/store/edu for details.
To make it short, you need:
- PC with DirectX 11 compatible graphics card
- Depending on type and number of cameras you may also need additional USB controller
What is the cost of hardware necessary to use the system?
Presuming you already have a PC with DirectX 11 compatible GPU,
For Express Edition:
- If you have Xbox One, you will only need cable for around $50
- Alternatively, you can use Kinect sensor, the cost is around $100
- Alternatively, you can use Kinect 2 for Windwos sensor, the cost is around $200
- Sony PS Eye cameras + USB cables, the total cost is around $160
- 2 Kinect sensors, the price of single sensor is around $100
- Or 2 Kinect 2 for Windows sensors, the price of single sensor is around $200
- Kinect floor stand (optional), the price is around $15 (2 items)
- Sony PS Eye camras + USB cables, the total cost is around $240 for 6 cameras configuration
- 1 or 2 USB controller(s), the total cost is around $30
- Tripods (optional), the total cost is around $80 (5 — 8 items)
- (optional) extra HDD for video recording (so that you do not record on your system drive), the cost may be around $50
Is there a version for Mac?
Biomech Add-on
Is Biomech Add-on free?
What is the accuracy of the tracking?
The overall accuracy is comparable with the accuracy of expensive marker mocap systems. We do not yet have precise numbers on accuracy, as this is the question of special research.
What export formats can I export data to?
Can I export to C3D?
Current version does not include export to C3D.
