ver. 3.2.2.189
N E W F E A T U R E S:
B U G F I X E S:
U N D E R T H E H O O D:
ver. 3.2.1.187
- Substantial speed-up of marker detection during the calibration. (Up to 3 times depending on hardware and settings)
B U G F I X E S:
ver. 3.2.0.182
- legs length
- arms length
- shoulders width
- head size
- feet size
ver. 3.1.2.177
- Biomech Add-on: added point cloud export formats convenient for animators, including Krakatoa PRT, PLY, OBJ, Leika PTS
ver. 3.1.1.175
B U G F I X E S:
ver. 3.1.0.173
B U G F I X E S:
ver. 3.0.3.172
B U G F I X E S:
- App crash when trying to remove an entry from the list of MRU hand poses
ver. 3.0.2.171
- Options for FBX export:
- FBX version;
- Binary/ASCII format.
- Reduced memory footprint.
B U G F I X E S:
ver. 3.0.1.169
B U G F I X E S:
ver. 3.0.0.166
- Improved calibration:
- more reliable
- faster
- automatic ground detection
- Redesigned user interface.
- Migration to DirectX 11.
