iPi Recorder Release Notes
ver. 3.1.2.36
N E W F E A T U R E S:
B U G F I X E S:
U N D E R T H E H O O D:
ver. 3.1.1.34
- Filtering out corrupted/absent files in the list of recent records
B U G F I X E S:
ver. 3.1.0.33
B U G F I X E S:
ver. 3.0.1.32
B U G F I X E S:
ver. 3.0.0.31
- available only for owners of iPi Mocap Studio license, including non-expired Free Trial
- Audio and video export.
