Video Recording
Revision as of 10:14, 21 October 2015 by Vmaslov (Talk | contribs)
iPi Recorder Setup
Framerate
4 cameras at 320 by 240 resolution
4 cameras at 640 by 480 resolution at 60 frames per second
6 cameras at 640 by 480 resolution at 60 frames per second
USB controllers
Performance Tips
  • Use dedicated physical drive (HDD or SSD, or even RAM drive when having enough memory) for recording onto it. When recording onto OS drive, performance may suffer badly from other working processes reading and writing to that drive in parallel.
  • During recording, unplug high-bandwidth USB devices like Wi-Fi adapters or external drives. This may prevent USB bandwidth problems for cameras causing frame drops or low frame rate.
