- 1 ver. 3.5.0.213
- 2 ver. 3.4.16.212
- 3 ver. 3.4.15.211
- 4 ver. 3.4.12.208
- 5 ver. 3.3.10.206
- 6 ver. 3.3.9.205
- 7 ver. 3.3.8.204
- 8 ver. 3.3.7.203
- 9 ver. 3.2.7.201
- 10 ver. 3.2.6.200
- 11 ver. 3.2.5.193
- 12 ver. 3.2.4.191
- 13 ver. 3.2.3.190
- 14 ver. 3.2.2.189
- 15 ver. 3.2.1.187
- 16 ver. 3.2.0.182
- 17 ver. 3.1.2.177
- 18 ver. 3.1.1.175
- 19 ver. 3.1.0.173
- 20 ver. 3.0.3.172
- 21 ver. 3.0.2.171
- 22 ver. 3.0.1.169
- 23 ver. 3.0.0.166
ver. 3.5.0.213
N E W F E A T U R E S:
- New fast tracking algorithm for depth sensors (BETA version).
- Maximum speed increase (up to 2.5 times) is achieved at high-performance video cards.
- To use it, turn on 'Use fast tracking algorithm (BETA)' checkbox on 'Tracking' tab.
- If you use 2 GPUs for tracking, you need to turn it off by unchecking second GPU via 'Help > Manage GPU Usage' menu.
- Now you can change character orientation when trasfering motion to imported characters.
B U G F I X E S:
- Video export crashed in case of window resizing during export.
U N D E R T H E H O O D:
ver. 3.4.16.212
B U G F I X E S:
ver. 3.4.15.211
B U G F I X E S:
- Fixed GPU memory leaks.
ver. 3.4.12.208
ver. 3.3.10.206
B U G F I X E S:
ver. 3.3.9.205
B U G F I X E S:
ver. 3.3.8.204
B U G F I X E S:
ver. 3.3.7.203
ver. 3.2.7.201
B U G F I X E S:
ver. 3.2.6.200
N E W F E A T U R E S:.
ver. 3.2.5.193
B U G F I X E S:
ver. 3.2.4.191
B U G F I X E S:
ver. 3.2.3.190
B U G F I X E S:
ver. 3.2.2.189
B U G F I X E S:
ver. 3.2.1.187
B U G F I X E S:
ver. 3.2.0.182
- legs length;
- arms length;
- shoulders width;
- head size;
- feet size.
ver. 3.1.2.177
ver. 3.1.1.175
B U G F I X E S:
ver. 3.1.0.173
B U G F I X E S:
ver. 3.0.3.172
B U G F I X E S:
ver. 3.0.2.171
- Options for FBX export:
- FBX version;
- Binary/ASCII format.
- Reduced memory footprint.
B U G F I X E S:
ver. 3.0.1.169
B U G F I X E S:
ver. 3.0.0.166
- Improved calibration:
- more reliable;
- faster;
- automatic ground detection;
- Redesigned user interface.
- Migration to DirectX 11.
