Cameras and Accessories
Sony PlayStation Eye for PS3
Logitech C922
- 60 FPS for 720p resolution.
- Tripod mounting screw.
Cameras Comparison
Which camera to choose?
| practical resolution(s) | 640x480 | 1280x720 | it depends | For iPi Motion Capture it is not so important to have high resolution. Higher resolution just allows to stand farther from camera, which potentially increases maximum capture area. But from the other side, higher resolution means slower processing in [iPi Mocap Studio]]. Thus if your top priority is the biggest capture area, then Logitech C922 wins. In other case - PS Eye wins. |
| price | under 10 USD | about 90 USD | PS Eye | Prices may differ for different regions. But in case PS Eye is significantly cheaper. |
Cables
Tripods
Video Card
USB controllers
All modern computers (e.g. dual-core and better) based on Intel, AMD and Nvidia chipsets have at least two high-speed USB (USB 2.0) controllers on board. With 2 controllers you've got enough bandwidth to record with:
USB hubs
Known compatibility issues
