Cameras and Accessories
Sony PlayStation Eye for PS3
Logitech C922
- 60 FPS for 720p resolution.
- Tripod mounting screw.
Cameras Comparison
Which camera to choose?
PS Eye | PS Eye has slightly bigger vertical field of view, this why actor can stand closer to camera and still be visible in full length. |
| connection | USB 2.0 (up to 2-4 cameras per USB-controller) | USB 2.0 (up to 2-4 cameras per USB-controller) | draw | Not more than two cameras should be connected to each USB controller to capture at 50 or 60 FPS. But some USB 3.0 controllers can handle up to four cameras at 50 and 60 FPS. This is true for both camera models. |
| price | under 10 USD | about 90 USD | PS Eye | Prices may differ for different regions. But in case PS Eye is significantly cheaper. |
Cables
Tripods
Video Card
USB controllers
All modern computers (e.g. dual-core and better) based on Intel, AMD and Nvidia chipsets have at least two high-speed USB (USB 2.0) controllers on board. With 2 controllers you've got enough bandwidth to record with:
USB hubs
Known compatibility issues
