- 1 ver. 3.6.6.222
- 2 ver. 3.6.4.220
- 3 ver. 3.6.3.219
- 4 ver. 3.6.2.218
- 5 ver. 3.6.1.217
- 6 ver. 3.6.0.216
- 7 ver. 3.5.1.215
- 8 ver. 3.5.0.214
- 9 ver. 3.4.16.212
- 10 ver. 3.4.15.211
- 11 ver. 3.4.12.208
- 12 ver. 3.3.10.206
- 13 ver. 3.3.9.205
- 14 ver. 3.3.8.204
- 15 ver. 3.3.7.203
- 16 ver. 3.2.7.201
- 17 ver. 3.2.6.200
- 18 ver. 3.2.5.193
- 19 ver. 3.2.4.191
- 20 ver. 3.2.3.190
- 21 ver. 3.2.2.189
- 22 ver. 3.2.1.187
- 23 ver. 3.2.0.182
- 24 ver. 3.1.2.177
- 25 ver. 3.1.1.175
- 26 ver. 3.1.0.173
- 27 ver. 3.0.3.172
- 28 ver. 3.0.2.171
- 29 ver. 3.0.1.169
- 30 ver. 3.0.0.166
ver. 3.6.6.222
N E W F E A T U R E S:
- Higher speed
- Slightly better accuracy
- get-actor-props; get-pose-mismatch; additional parameters for set-actor-props
- recenter-coordinates-on-character; move-coordinate-system
- export-video; videoFilePath parameter in open-project command
- Added option to take .iPiVideo from project directory if .iPiVideo is not found
- Allow fractional values for target FPS in Export Options dialog
B U G F I X E S:
- Incorrect Biomech export for multiple actors; first actor exported correctly, other actors used bone lengths of first actor
- Uneven shoulder height was set for some imported characters
- Taking into account target character transform when exporting cameras
U N D E R T H E H O O D:
- Auto adjust camera FOV is checked by default for calibration project (in case when all RGB cameras have the same model)
- FBX import: improved search for a root node
ver. 3.6.4.220
B U G F I X E S:
ver. 3.6.3.219
B U G F I X E S:
- App crash
- Visual glitches
ver. 3.6.2.218
B U G F I X E S:
ver. 3.6.1.217
B U G F I X E S:
ver. 3.6.0.216
- Vastly greater speed
- Automation add-on:
true.
B U G F I X E S:
ver. 3.5.1.215
B U G F I X E S:
ver. 3.5.0.214
B U G F I X E S:
ver. 3.4.16.212
B U G F I X E S:
ver. 3.4.15.211
B U G F I X E S:
- Fixed GPU memory leaks.
ver. 3.4.12.208
ver. 3.3.10.206
B U G F I X E S:
ver. 3.3.9.205
B U G F I X E S:
ver. 3.3.8.204
B U G F I X E S:
ver. 3.3.7.203
ver. 3.2.7.201
B U G F I X E S:
ver. 3.2.6.200
N E W F E A T U R E S:.
ver. 3.2.5.193
B U G F I X E S:
ver. 3.2.4.191
B U G F I X E S:
ver. 3.2.3.190
B U G F I X E S:
ver. 3.2.2.189
B U G F I X E S:
ver. 3.2.1.187
B U G F I X E S:
ver. 3.2.0.182
- legs length;
- arms length;
- shoulders width;
- head size;
- feet size.
ver. 3.1.2.177
ver. 3.1.1.175
B U G F I X E S:
ver. 3.1.0.173
B U G F I X E S:
ver. 3.0.3.172
B U G F I X E S:
ver. 3.0.2.171
- Options for FBX export:
- FBX version;
- Binary/ASCII format.
- Reduced memory footprint.
B U G F I X E S:
ver. 3.0.1.169
B U G F I X E S:
ver. 3.0.0.166
- Improved calibration:
- more reliable;
- faster;
- automatic ground detection;
- Redesigned user interface.
- Migration to DirectX 11.
