iPi Recorder Release Notes
ver. 4.0.1.61
B U G F I X E S:
- Backround was not discarded in case of certain changes of the recording settings
N E W F E A T U R E S:
- Support of the new depth sensors:
- Intel RealSense D415 / D435
- Orbbec Astra / Astra PRO
- ASUS Xtion2
- Tool for precise calibration of cameras (this allows to determine camera internal parameters, including distortion)
- Support of workflow with action cameras like GoPro and Sjcam
- Real-time Tracking for Live Preview: live data streaming to iPi Mocap Studio
ver. 3.3.2.57
B U G F I X E S:
ver. 3.3.1.56
B U G F I X E S:
ver. 3.3.0.55
B U G F I X E S:
U N D E R T H E H O O D:
ver. 3.2.11.53
B U G F I X E S:
ver. 3.2.9.51
B U G F I X E S:
ver. 3.2.8.50
B U G F I X E S:
ver. 3.2.7.49
B U G F I X E S:
ver. 3.2.6.48
B U G F I X E S:
ver. 3.2.5.47
B U G F I X E S:
ver. 3.2.3.45
ver. 3.1.4.43
ver. 3.1.3.38
- Memory usage optimizations.
ver. 3.1.2.36
B U G F I X E S:
ver. 3.1.1.34
B U G F I X E S:
ver. 3.1.0.33
B U G F I X E S:
ver. 3.0.1.32
B U G F I X E S:
ver. 3.0.0.31
- Audio and video export.
