iPi Recorder Release Notes
Revision as of 11:48, 19 July 2018 by Vmaslov (Talk | contribs)
ver. 4.0.3.63
Version 4.0.3.63
Jul 19, 2018
Download-24.png  Download
 B U G    F I X E S:
ver. 4.0.1.61
Version 4.0.1.61
Jul 03, 2018
 N E W    F E A T U R E S:
  • Support for the new depth sensors:
  • Tool for precise calibration of cameras that allows to determine camera internal parameters, including distortion.
  • Powerful video builder, which allows to combine/edit video from different sources, (re)evaluate background, set/patch inter-cameras synchronization, etc.
  • Support for workflow with action cameras like GoPro and SJCAM.
  • Real-time Tracking for Live Preview: live data streaming to iPi Mocap Studio.
 B U G    F I X E S:
ver. 3.3.2.57
Version 3.3.2.57
Oct 23, 2017
 B U G    F I X E S:
ver. 3.3.1.56
Version 3.3.1.56
Oct 13, 2017
 B U G    F I X E S:
ver. 3.3.0.55
Version 3.3.0.55
Aug 14, 2017
 B U G    F I X E S:
ver. 3.2.11.53
Version 3.2.11.53
Jun 12, 2017
 B U G    F I X E S:
ver. 3.2.9.51
Version 3.2.9.51
Apr 28, 2017
 B U G    F I X E S:
ver. 3.2.8.50
Version 3.2.8.50
Apr 25, 2017
 B U G    F I X E S:
ver. 3.2.7.49
Version 3.2.7.49
Mar 07, 2017
 B U G    F I X E S:
ver. 3.2.6.48
Version 3.2.6.48
Jan 25, 2017
 B U G    F I X E S:
ver. 3.2.5.47
Version 3.2.5.47
Nov 10, 2016
 B U G    F I X E S:
ver. 3.2.3.45
Version 3.2.3.45
Jul 14, 2016
ver. 3.1.4.43
Version 3.1.4.43
Apr 25, 2016
ver. 3.1.3.38
Version 3.1.3.38
Nov 19, 2015
  • Memory usage optimizations.
ver. 3.1.2.36
Version 3.1.2.36
Jun 18, 2015
 B U G    F I X E S:
ver. 3.1.1.34
Version 3.1.1.34
Mar 06, 2015
 B U G    F I X E S:
ver. 3.1.0.33
Version 3.1.0.33
Dec 29, 2014
 B U G    F I X E S:
ver. 3.0.1.32
Version 3.0.1.32
Nov 13, 2014
 B U G    F I X E S:
ver. 3.0.0.31
Version 3.0.0.31
Nov 03, 2014
