iPi Recorder Release Notes
- 1 ver. 4.2.2.72
- 2 ver. 4.2.1.71
- 3 ver. 4.2.0.70
- 4 ver. 4.1.0.69
- 5 ver. 4.0.7.67
- 6 ver. 4.0.5.65
- 7 ver. 4.0.4.64
- 8 ver. 4.0.3.63
- 9 ver. 4.0.1.61
- 10 ver. 3.3.2.57
- 11 ver. 3.3.1.56
- 12 ver. 3.3.0.55
- 13 ver. 3.2.11.53
- 14 ver. 3.2.9.51
- 15 ver. 3.2.8.50
- 16 ver. 3.2.7.49
- 17 ver. 3.2.6.48
- 18 ver. 3.2.5.47
- 19 ver. 3.2.3.45
- 20 ver. 3.1.4.43
- 21 ver. 3.1.3.38
- 22 ver. 3.1.2.36
- 23 ver. 3.1.1.34
- 24 ver. 3.1.0.33
- 25 ver. 3.0.1.32
- 26 ver. 3.0.0.31
ver. 4.2.2.72
B U G F I X E S:
- Infinite continuous auto-refreshing of device list on home screen when using libfreenect2 to work with Kinect v2.
- Device lost during background evaluation when using libfreenect2 to work with multiple Kinect v2 devices.
ver. 4.2.1.71
N E W F E A T U R E S:
B U G F I X E S:
U N D E R T H E H O O D:
ver. 4.2.0.70
ver. 4.1.0.69
ver. 4.0.7.67
B U G F I X E S:
ver. 4.0.5.65
B U G F I X E S:
ver. 4.0.4.64
B U G F I X E S:
ver. 4.0.3.63
B U G F I X E S:
ver. 4.0.1.61
- Intel RealSense D415 / D435
- Orbbec Astra / Astra PRO
- ASUS Xtion2
B U G F I X E S:
ver. 3.3.2.57
B U G F I X E S:
ver. 3.3.1.56
B U G F I X E S:
ver. 3.3.0.55
B U G F I X E S:
ver. 3.2.11.53
B U G F I X E S:
ver. 3.2.9.51
B U G F I X E S:
ver. 3.2.8.50
B U G F I X E S:
ver. 3.2.7.49
B U G F I X E S:
ver. 3.2.6.48
B U G F I X E S:
ver. 3.2.5.47
B U G F I X E S:
ver. 3.2.3.45
ver. 3.1.4.43
ver. 3.1.3.38
- Memory usage optimizations.
ver. 3.1.2.36
B U G F I X E S:
ver. 3.1.1.34
B U G F I X E S:
ver. 3.1.0.33
B U G F I X E S:
ver. 3.0.1.32
B U G F I X E S:
ver. 3.0.0.31
- Audio and video export.
