iPi Recorder Release Notes
- 1 ver. 4.5.0.82
- 2 ver. 4.4.4.81
- 3 ver. 4.4.0.77
- 4 ver. 4.3.2.75
- 5 ver. 4.3.1.74
- 6 ver. 4.3.0.73
- 7 ver. 4.2.2.72
- 8 ver. 4.2.1.71
- 9 ver. 4.2.0.70
- 10 ver. 4.1.0.69
- 11 ver. 4.0.7.67
- 12 ver. 4.0.5.65
- 13 ver. 4.0.4.64
- 14 ver. 4.0.3.63
- 15 ver. 4.0.1.61
- 16 ver. 3.3.2.57
- 17 ver. 3.3.1.56
- 18 ver. 3.3.0.55
- 19 ver. 3.2.11.53
- 20 ver. 3.2.9.51
- 21 ver. 3.2.8.50
- 22 ver. 3.2.7.49
- 23 ver. 3.2.6.48
- 24 ver. 3.2.5.47
- 25 ver. 3.2.3.45
- 26 ver. 3.1.4.43
- 27 ver. 3.1.3.38
- 28 ver. 3.1.2.36
- 29 ver. 3.1.1.34
- 30 ver. 3.1.0.33
- 31 ver. 3.0.1.32
- 32 ver. 3.0.0.31
ver. 4.5.0.82
N E W F E A T U R E S:
B U G F I X E S:
ver. 4.4.4.81
B U G F I X E S:
U N D E R T H E H O O D:
ver. 4.4.0.77
ver. 4.3.2.75
B U G F I X E S:
ver. 4.3.1.74
ver. 4.3.0.73
B U G F I X E S:
ver. 4.2.2.72
B U G F I X E S:
ver. 4.2.1.71
B U G F I X E S:
ver. 4.2.0.70
ver. 4.1.0.69
ver. 4.0.7.67
B U G F I X E S:
ver. 4.0.5.65
B U G F I X E S:
ver. 4.0.4.64
B U G F I X E S:
ver. 4.0.3.63
B U G F I X E S:
ver. 4.0.1.61
- Intel RealSense D415 / D435
- Orbbec Astra / Astra PRO
- ASUS Xtion2
B U G F I X E S:
ver. 3.3.2.57
B U G F I X E S:
ver. 3.3.1.56
B U G F I X E S:
ver. 3.3.0.55
B U G F I X E S:
ver. 3.2.11.53
B U G F I X E S:
ver. 3.2.9.51
B U G F I X E S:
ver. 3.2.8.50
B U G F I X E S:
ver. 3.2.7.49
B U G F I X E S:
ver. 3.2.6.48
B U G F I X E S:
ver. 3.2.5.47
B U G F I X E S:
ver. 3.2.3.45
ver. 3.1.4.43
ver. 3.1.3.38
- Memory usage optimizations.
ver. 3.1.2.36
B U G F I X E S:
ver. 3.1.1.34
B U G F I X E S:
ver. 3.1.0.33
B U G F I X E S:
ver. 3.0.1.32
B U G F I X E S:
ver. 3.0.0.31
- Audio and video export.
