iPi Automation Add-on
Revision as of 14:38, 7 May 2021 by Andrew (Talk | contribs)
Using iPi Automation Add-on
Communication Library
    • x86 32-bit version
    • x64 64-bit version
iPiExec Console Application
Using iPiExec
SAMPLE
>ipiexec recorder
Connecting to iPi Recorder...
Connected!
RECORDER >
ParameterDescription
jsonEventEvent string.
ConstantDescription
IPI_OKOperation succeeded.
    "arguments":
        <arguments_list_json_string>
    "success": true
    "success": true,
    "result":
      <result_json_string>
// Response in case of error
    "success": false,
// Event without arguments
// Event including arguments
    "arguments":
iPi Recorder Commands
Parameter NameTypeMandatory /
Optional
Allowed ValuesDescription
Arguments
No arguments
Result
// Request
// Response
    "success":true,
    "result":
        "appName": "iPi Recorder 3",
        "mainWindowHandle":524736,
        "processId":12368
Optional
Arguments
Result
Empty result
// Request
    "command": "open-studio",
    "arguments":
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "exit"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "open-home-screen"
// Response
    "success": true
Optional
Arguments
No arguments
Result
kindstringmandatorycamera
depth-sensor
microphone
Device type.
selectedbooleanmandatorytrue
false
Device selected status.
failedbooleanmandatorytrue
false
Device failed status.
// Request
// Response
    "success":true,
    "result":
            "kind": "camera",
            "model": "PlayStation Eye",
            "selected": false,
            "failed": false
            "kind": "depth-sensor",
            "id": "Default Kinect 2",
            "selected": true,
            "failed": true,
            "error": "Is not available"
            "kind": "microphone",
            "selected": false,
            "failed": false
Optional
Arguments
Result
Empty result
// Request
    "command": "open-recorder",
    "arguments":
        "selectedDevices":
// Response
    "success":true
Optional
Arguments
Result
Empty result
Events
successbooleanmandatorytrue
false
cancelledbooleanmandatorytrue
false
// Request
    "arguments":
        "duration": 3,
        "startDelay": 1
// Response
    "success": true
// Event
    "arguments":
        "success": true,
        "cancelled": false
Optional
Arguments
screenstringmandatorysetup
background
record
Result
Empty result
// Request
    "command": "go-to-screen",
    "arguments":
        "screen": "record"
// Response
    "success": true
Optional
Arguments
forceStartbooleanoptionaltrue
false
Result
Empty result
Events
yyyy-MM-ddTHH:mm:ss.sssssss
false
false
hh:mm:ss.sssssss
false
// Request
    "command": "start-recording",
    "arguments":
        "startDelay": 1,
        "forceStart": true
// Response
    "success": true
// Event
    "event": "recording-started",
    "arguments":
// Event
    "event": "recording-stopped",
    "arguments":
        "success": true,
        "cancelled": false,
        "fileSize": 39975560,
        "frameCount": 197,
        "statistics" :
                        "devicesStatistics" :
                                        "badFramesPerSecond" :
                                                "average" : 0,
                                                "deviation" : 0,
                                                "max" : 0,
                                                "min" : 0
                                        "frameGapsPerSecond" :
                                                "average" : 0,
                                                "deviation" : 0,
                                                "max" : 0,
                                                "min" : 0
                                        "framesPerSecond" :
                                                "average" : 60.2884,
                                                "deviation" : 0.436367,
                                                "max" : 62.5,
                                                "min" : 60
                                        "maxFrameGap" : 0,
                                        "maxSpanOfBadFrames" : 0,
                                        "totalBadFrames" : 0,
                                        "totalFrameGaps" : 0
                                                "average" : 0,
                                                "deviation" : 0,
                                                "max" : 0,
                                                "min" : 0
                                                "average" : 0,
                                                "deviation" : 0,
                                                "max" : 0,
                                                "min" : 0
                                        "framesPerSecond" :
                                                "average" : 60.3032,
                                                "deviation" : 0.450399,
                                                "max" : 62.5,
                                                "min" : 60
                                        "maxFrameGap" : 0,
                                                "average" : 0,
                                                "deviation" : 0,
                                                "max" : 0,
                                                "min" : 0
                                                "average" : 0,
                                                "deviation" : 0,
                                                "max" : 0,
                                                "min" : 0
                                        "framesPerSecond" :
                                                "average" : 60.2264,
                                                "deviation" : 0.321094,
                                                "max" : 61.7,
                                                "min" : 60
                                        "maxFrameGap" : 0,
                        "overallStatistics" :
                                        "average" : 0,
                                        "deviation" : 0,
                                        "max" : 0,
                                        "min" : 0
                                "deviceName" : "Overall",
                                        "average" : 0,
                                        "deviation" : 0,
                                        "max" : 0,
                                        "min" : 0
                                "framesPerSecond" :
                                        "average" : 60.2701,
                                        "deviation" : 0.39055,
                                        "max" : 62.1,
                                        "min" : 60
                                "maxFrameGap" : 0,
                        "primaryChannelMistiming" :
                                "average" : 0.00180621,
                                "deviation" : 0.000746511,
                                "max" : 0.0073028,
                                "min" : 3.39e-005
                        "secondaryChannelMistiming" :
                                "average" : 0,
                                "deviation" : 0,
                                "max" : 0,
                                "min" : 0
Optional
Arguments
No arguments
Result
Empty result
Events
false
false
hh:mm:ss.sssssss
false
// Request
    "command": "stop-recording"
// Response
    "success": true
// Event
    "arguments":
        "success": true,
        "cancelled": false,
        "frameCount": 197
Optional
Arguments
No arguments
Result
depth-sensor
microphone
Device type.
false
false
statisticsJSON object
optional
Camera statistics.
// Request
// Response
    "success":true,
    "result":
            "kind": "camera",
            "index": 1,
            "selected": true,
            "failed": false,
            "statistics":
                "frameRate": 50.0,
                "frameDropsPerSecond": 0.0,
                "badFramesPerSecond": 0.0,
                "totalFrameDrops": 0,
                "totalBadFrames": 0,
                "backgroundAreaPercent": 76
            "index": 2,
            "selected": true,
            "failed": false,
            "statistics":
                "frameRate": 50.0,
                "backgroundAreaPercent": 98
Optional
Arguments
No arguments
Result
Properties for SETUP Stage:
videoModestringmandatory
Selected RGB video mode.
Possible videoMode values.
"Landscape"
"Portrait"
audioModestringoptional
globalDevicePropsJSON object
optional
"Darkening"
"Extra Darkening"
screenLayoutstringmandatory
For RGB cameras:
"Color"
For depth sensors:
"Depth"
"Picture in picture"
"Side by side"
Selected screen layout.
false
Properties for RECORD Stage:
false
Valid file path
"None"
"Background subtraction"
"JPEG"
// Request
// Response
    "success": true,
    "result":
        "videoModeList":
            "640x480 color @ 60Hz",
            "640x480 color @ 40Hz",
            "640x480 color @ 30Hz",
            "640x480 color @ 25Hz",
            "320x240 color @ 60Hz",
            "320x240 color @ 50Hz",
            "320x240 color @ 37Hz",
            "320x240 color @ 30Hz"
        "screensInRow": 1,
        "screenLayout": "Color",
        "screenLayoutList":
            "Color"
        "globalDeviceProps":
                "None",
                "Darkening",
                "Extra Darkening"
        "recordingStartDelay": 1,
        "colorCompression": "Jpeg",
        "jpegQuality": 100,
Optional
Arguments
videoModestringoptional
"Landscape"
"Portrait"
optional
"Darkening"
"Extra Darkening"
screenLayoutstringoptional
For RGB cameras:
"Color"
For depth sensors:
"Depth"
"Side by side"
Setting screen layout.
false
false
Valid file path
"None"
"JPEG"
Result
Empty result
// Request
    "arguments":
        "colorCompression": "jpeg",
    "recordingStartDelay": 0,
// Response
    "success": true
discover-slaves
Optional
Arguments
Result
// Request
    "command": "discover-slaves",
    "arguments":
// Response
    "success": true,
connect-to-slaves
Optional
Arguments
Result
// Request
    "arguments":
// Response
    "success": true,
    "result": ["PC-MIKE"]
disconnect-from-slaves
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true,
enter-slave-mode
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "enter-slave-mode"
// Response
    "success": true,
exit-slave-mode
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "exit-slave-mode"
// Response
    "success": true,
start-broadcasting
{{{events}}}
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
stop-broadcasting
{{{events}}}
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
merge-videos
Optional
Arguments
Resulting iPiVideo file.
Result
Empty result
Events
false
false
// Request
    "command": "merge-videos",
    "arguments":
// Response
    "success": true
// Event
    "arguments":
        "success": true,
        "cancelled": false
Optional
Arguments
false
Result
Empty result
// Request
    "arguments":
        "screensInRow": 2,
	"hideBackground": true
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "command": "open-player",
    "arguments":
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
Events
No event arguments
// Request
    "command": "play-forward"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "play-backward"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "frame-forward"
// Response
    "success": true,
    "error": "Last frame reached"
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "frame-backward"
// Response
    "success": true,
Optional
Arguments
Result
Empty result
// Request
    "command": "go-to-frame",
    "arguments":
        "frameIndex": 27
// Response
    "success": true
iPi Mocap Studio Commands
Optional
Arguments
No arguments
Result
// Request
// Response
    "success":true,
    "result":
        "mainWindowHandle":19925022,
        "processId":7328
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "exit"
// Response
    "success": true
Action projects
Optional
Arguments
genderstringoptionalfemale
male
tshirt
tshirtoverlongsleeveshirt
Actor clothing model.
Result
Empty result
// Request
    "command": "create-project",
    "arguments":
        "projectType": "action",
Calibration projects
Optional
Arguments
false
false
Result
Empty result
// Request
    "arguments":
        "projectType": "calibration",
        "cameraFov": 80,
Optional
Arguments
Result
Empty result
// Request
    "command": "open-project",
    "arguments":
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "command": "save-project",
    "arguments":
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "close-project"
// Response
    "success": true
Optional
Arguments
No arguments
Result
calibration
dummy
RGB
Type of the cameras.
// Request
    "command": "get-project-info"
// Response
    "success":true,
    "result":
        "camerasType": "RGB",
        "camerasCount": 6
Optional
Arguments
No arguments
Result
// Request
// Response
    "success": true,
    "result":
        "timeline":
            "beginFrame": 0,
            "framesCount": 758,
            "secondsPerFrame": 0.02,
            "durationInSeconds": 15.1399
        "regionOfInterest":
            "beginFrame": 0,
            "framesCount": 758,
            "durationInSeconds": 15.1399,
        "takes":
                "beginFrame": 0,
                "framesCount": 758,
                "description": "Take 1"
Optional
Arguments
Result
Empty result
// Request
    "arguments":
        "regionOfInterest":
            "beginFrame": 10,
            "framesCount": 558,
        "takes":
                "beginFrame": 10,
                "framesCount": 158,
                "beginFrame": 200,
                "framesCount": 558,
                "description": "Take 2"
// Response
    "success": true
Optional
Arguments
No arguments
Result
General view properties
skinbooleanmandatorytrue
false
Show skin flag value.
bonesbooleanmandatorytrue
false
Show bones flag value.
camerasbooleanmandatorytrue
false
Show cameras flag value.
false
Show ground plane flag value.
false
Show background flag value.
false
Show trajectories flag value.
false
false
false
false
Show mass objects flag value.
false
videobooleanmandatorytrue
false
Show video flag value.
false
false
Show light source flag value.
depthbooleanmandatorytrue
false
Show depth flag value.
false
Hide background flag value.
false
false
false
// Request
    "command": "get-view-props"
// Response
    "success": true,
    "result":
        "skin": true,
        "skinOpacity": 0.7,
        "bones": true,
        "cameras": true,
        "currentCamera": 0,
        "groundPlane": true,
        "viewBackground": false,
        "currentActor": 0,
        "trajectories": false,
        "skeletonStrobe": false,
        "extraSkeletonStrobe": false,
        "collisionObjects": false,
        "massObjects": false,
        "poseMismatch": false,
        "video": true,
        "videoOpacity": 0.7,
        "videoThumbnails": true,
        "lightSource": true
Optional
Arguments
skinbooleanoptionaltrue
false
bonesbooleanoptionaltrue
false
camerasbooleanoptionaltrue
false
false
false
false
false
false
false
false
false
videobooleanoptionaltrue
false
false
false
depthbooleanoptionaltrue
false
false
false
false
false
Result
Empty result
// Request
    "command": "set-view-props",
    "arguments":
        "currentActor": 0,
        "skin": false,
        "skinOpacity": 0.5,
        "bones": true,
        "cameras": true,
        "currentCamera": 2,
        "videoOpacity": 0.6,
        "videoThumbnails": false,
        "lightSource": true
// Response
    "success": true
Scene Commands
Optional
Arguments
Result
Empty result
// Request
    "command": "load-scene",
    "arguments":
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "command": "save-scene",
    "arguments":
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
move-coordinate-system
Optional
Arguments
Result
Empty result
// Request
    "arguments":
        "shiftX": 0.23,
        "shiftY": -0.02,
        "shiftZ": -0.6,
        "cameraAzimuth": 0.0
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "command": "load-actor",
    "arguments":
        "actorIndex": 0,
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "command": "save-actor",
    "arguments":
        "actorIndex": 0,
// Response
    "success": true
Optional
Arguments
false
Result
Empty result
Events
// Request
    "arguments":
        "handsColorSameAsFace": false
// Response
    "success": true
// Event
    "arguments":
        "shirtColor":"#384662",
        "pantsColor":"#1F2431",
        "handsColor":"#9A9DA6",
        "faceColor":"#7A7077",
        "shoesColor":"#504C4C",
        "shoeSolesColor":"#504C4C",
        "hairColor":"#57555E",
        "sleevesColor":"#384662"
get-actor-props
Optional
Arguments
No arguments
Result
genderstringmandatoryfemale
male
Gender of actor.
tshirt
dimensionsJSON object
optional
Actor dimensions.
// Request
    "command": "get-actor-props"
// Response
    "success": true,
    "result":
        "gender": "female",
        "height": 1.8,
        "dimensions":
            "headHeight": 0.21,
            "shouldersWidth": 0.3,
            "armLength": 0.57,
            "legLength": 0.89,
            "footLength": 0.26
Optional
Arguments
male
Gender of actor.
tshirt
optional
Actor dimensions.
Result
Empty result
// Request
    "command": "set-actor-props",
    "arguments":
        "gender": "female",
        "height": 1.8,
        "dimensions":
            "headHeight": 0.21,
            "armLength": 0.57,
            "legLength": 0.89,
            "footLength": 0.26
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": false,
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "arguments":
        "frameIndex": 27
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "pause-play"
// Response
    "success": true
export-video
Optional
Arguments
Jpeg
Video encoding.
Result
Empty result
// Request
    "command": "export-video",
    "arguments":
        "encoding": "jpeg",
        "quality": 70,
        "takeIndex": 0
// Response
    "success": true
// Event
    "arguments":
        "elapsedTime": 62.321,
        "fps": 4.05963,
        "framesProcessed": 253
Optional
Arguments
No arguments
Result
false
false
false
false
1 - Tracked from video
0 - Stiff Lower Spine
1 - Flexible Lower Spine
2 - Very Flexible Lower Spine
Selected spine tracking mode.
0 - High
1 - Low
Selected tracking resolution.
Item 0 - value for Torso
Item 1 - value for Left arm
Item 2 - value for Right arm
Item 3 - value for Left leg
Item 4 - value for Right leg
Item 5 - value for Head
// Request
// Response
    "success": true,
    "result":
        "enableFootTracking": true,
        "enableHeadTracking": true,
        "shouldersTrackingMode": 1,
        "spineTrackingMode": 0,
        "trackingResolution": 0,
        "trajectoryFilter": 2
Optional
Arguments
false
false
false
0 - High
1 - Low
false
Result
Empty result
// Request
    "arguments":
        "enableHeadTracking": false,
        "shouldersTrackingMode": 0,
        "spineTrackingMode": 2,
        "trajectoryFilter": 3
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
Events
xnumberDouble x cooordinate.
ynumberDouble y cooordinate.
znumberDouble z cooordinate.
wnumberDouble w cooordinate.
// Request
    "command": "refit-pose"
// Response
    "success": true
// Event
    "arguments":
        "translation":
            "x": 0.20735317468643188,
            "y": 0.93647444248199463,
            "z": 0.1268109530210495
        "joints":
                "name": "Hip",
                "rotation":
                    "w": 0.99089264869689941,
                    "x": -0.024765072390437126,
                    "y": -0.13141168653964996,
                    "z": -0.015792140737175941
                "name": "LowerSpine",
                "rotation":
                    "w": 0.9960486888885498,
                    "x": 0.028381859883666039,
                    "y": -0.083706416189670563,
                    "z": -0.008648967370390892
                "name": "MiddleSpine",
                "rotation":
                "name": "Chest",
                "rotation":
                "name": "Neck",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
                "name": "Head",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
                "name": "EffectorHead",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
                "name": "LClavicle",
                "rotation":
                    "w": 0.99793654680252075,
                    "x": 0.0059945755638182163,
                    "y": 0.046108484268188477,
                    "z": 0.044281467795372009
                "name": "LShoulder",
                "rotation":
                    "w": 0.9549943208694458,
                    "x": -0.034553475677967072,
                    "y": 0.29447850584983826,
                    "z": 0.0086394213140010834
                "name": "LForearm",
                "rotation":
                    "w": 0.91743868589401245,
                    "x": -0.036340668797492981,
                    "y": -0.39591813087463379,
                    "z": 0.015319216065108776
                "name": "LHand",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
                "name": "RClavicle",
                "rotation":
                    "w": 0.995156466960907,
                    "x": -0.040068801492452621,
                    "y": -0.048379208892583847,
                    "z": 0.075615249574184418
                "name": "RShoulder",
                "rotation":
                    "w": 0.965262770652771,
                    "x": -0.0052053602412343025,
                    "y": 0.26098120212554932,
                    "z": -0.011395715177059174
                "name": "RForearm",
                "rotation":
                    "w": 0.99951714277267456,
                    "x": -0.020441532135009766,
                    "y": -0.0027645230293273926,
                    "z": -0.023236606270074844
                "name": "RHand",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
                "name": "RThigh",
                "rotation":
                    "w": 0.79308795928955078,
                    "x": 0.068257540464401245,
                    "y": 0.60094189643859863,
                    "z": 0.072259068489074707
                "name": "RShin",
                "rotation":
                    "w": 0.79541802406311035,
                    "x": 0.053630385547876358,
                    "y": 0.60230922698974609,
                    "z": -0.040715586394071579
                "name": "RFoot",
                "rotation":
                    "w": 0.99298214912414551,
                    "x": -0.11810562759637833,
                    "y": -0.00553984334692359,
                    "z": -0.0026492751203477383
                "name": "RToe",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
                "name": "EffectorRToe",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
                "name": "LThigh",
                "rotation":
                    "w": 0.99825394153594971,
                    "x": -0.0010303414892405272,
                    "y": 0.021972890943288803,
                    "z": 0.054818056523799896
                "name": "LShin",
                "rotation":
                    "w": 0.99794912338256836,
                    "x": 0.059693548828363419,
                    "y": 0.023080151528120041,
                    "z": -0.0013148610014468431
                "name": "LFoot",
                "rotation":
                    "w": 0.98020839691162109,
                    "x": -0.18852591514587402,
                    "y": -0.054500121623277664,
                    "z": -0.026062563061714172
                "name": "LToe",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
                "name": "EffectorLToe",
                "rotation":
                    "w": 1.0,
                    "x": 0.0,
                    "y": 0.0,
                    "z": 0.0
get-pose-mismatch
Optional
Arguments
No arguments
Result
// Request
// Response
    "success": true,
    "result":
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "delete-pose"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
Events
// Request
    "command": "track-forward"
// Response
    "success": true
// Event
    "arguments":
        "framesProcessed": 253,
        "fps": 4.05963,
// Event
    "event": "progress-updated",
    "arguments":
        "elapsedTime": 5.3501876,
        "fps":6.169
Optional
Arguments
No arguments
Result
Empty result
Events
// Request
    "command": "track-backward"
// Response
    "success": true
// Event
    "arguments":
        "fps": 4.05963,
// Event
    "arguments":
        "fps":6.169
Optional
Arguments
No arguments
Result
Empty result
Events
// Request
    "command": "refine-forward"
// Response
    "success": true
// Event
    "arguments":
        "fps": 4.05963,
// Event
    "arguments":
        "fps":6.169
Optional
Arguments
No arguments
Result
Empty result
Events
// Request
    "command": "refine-backward"
// Response
    "success": true
// Event
    "arguments":
        "fps": 4.05963,
// Event
    "arguments":
        "fps":6.169
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "pause-tracking"
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
Events
// Request
    "command": "remove-jitter"
// Response
    "success": true
// Event
    "arguments":
        "fps": 4.05963,
// Event
    "arguments":
        "fps":6.169
start-live-session
{{{events}}}
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
end-live-session
{{{events}}}
Optional
Arguments
No arguments
Result
Empty result
// Request
    "command": "end-live-session"
// Response
    "success": true
discover-live-sources
{{{events}}}
Optional
Arguments
Result
// Request
    "arguments":
// Response
    "success": true,
{{{events}}}
Optional
Arguments
Result
// Request
    "arguments":
        "hostNames": ["PC-MIKE"],
// Response
    "success": true,
disconnect-from-live-sources
{{{events}}}
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
start-live-recording
{{{events}}}
Optional
Arguments
Result
// Request
    "arguments":
// Response
    "success": true,
    "result":
stop-live-recording
{{{events}}}
Optional
Arguments
No arguments
Result
// Request
// Response
    "success": true,
    "result":
        "frameCount": 900,
        "duration": "00:00:30.000000"
Optional
Arguments
Result
Empty result
// Request
    "arguments":
// Response
    "success": true
Optional
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
Optional
Arguments
formatstringmandatorytext
matlab
clipboard
Export format.
Result
Empty result
Events
No event arguments
// Request
    "arguments":
        "format": "text",
// Response
    "success": true
// Event
    "arguments":
        "success": true
Optional
Arguments
formatstringmandatorypcd
obj
matlab
ply
pts
prt
xyz
Export format.
false
exportRGBbooleanoptionaltrue
false
false
Result
Empty result
Events
// Request
    "arguments":
        "format": "pcd",
        "folderPath": "D:\\iPiMocap",
        "fileName": "test.pcd",
        "subtractBackground": true,
        "exportRGB": true
// Response
    "success": true
// Event
    "arguments":
        "fps": 4.05963,
Optional
Arguments
medium
large
false
false
normal
extended
extreme
boardbooleanoptionaltrue
false
Result
Empty result
Events
canceledbooleanmandatorytrue
false
qualitystringmandatoryfailed
good
perfect
unknown
Camera calibration quality.
good
perfect
unknown
good
perfect
unknown
// Request
    "command": "run-calibration",
    "arguments":
        "markerSpotSize": "large",
        "markerColor": "#0099FF",
        "calibrationMode": "fast"
// Response
    "success": true
// Event
    "arguments":
        "elapsedTime": 49.0548727,
        "canceled": false,
        "rgbCalibrationStat":
                "quality": "perfect",
                "misdetects": 0.36743924
                "misdetects": 0.328137815
                "misdetects": 0.5209761
                "misdetects": 1.13636363
// Event
    "arguments":
        "fps":6.169
Optional
Arguments
Result
Empty result
// Request
    "arguments":
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "arguments":
// Response
    "success": true
Optional
Arguments
rigNamestringoptionaldefault
motionbuilder
3dsmax
endorphin
iclone
blender
Name of predefined rig.
Result
Empty result
// Request
    "arguments":
        "rigName": "3dsmax"
// Response
    "success": true
Optional
Arguments
Result
Empty result
// Request
    "arguments":
// Response
    "success": true
Optional
Arguments
No arguments
Result
false
false
false
// Request
    "command": "get-export-props"
// Response
    "success": true,
    "result":
Optional
Arguments
false
false
false
Result
Empty result
// Request
    "arguments":
// Response
    "success": true
Optional
Arguments
fbxIsBinarystringoptionaltrue
false
fbxVersionstringoptional2014
2013
2012
2011
2010
Fbx version for FBX format.
false
Default is false.
Result
Empty result
// Request
    "arguments":
        "targetFrameRate": 30
// Response
    "success": true
start-streaming-animation
{{{events}}}
Optional
Arguments
Result
Empty result
// Request
// Response
    "success": true
stop-streaming-animation
{{{events}}}
Parameter NameTypeMandatory /
Optional
Allowed ValuesDescription
Arguments
No arguments
Result
Empty result
// Request
// Response
    "success": true
